Dibs-h
Chaps
Some progress - below is the 1st quote,
The last 2 entries - i.e. Rings 3 & 4, these don't represent anything for the majority, but are to allow for the use of Porter Cable bushes or similar and are due to the request from Jerome (SometimesWoodWorker)
AL - means Aluminium & M means Mild Steel.
Disc 1 - disc with no hole,
Ring 1 - 30mm hole
Ring 2 - 50 mm hole.
This makes an AL set come in at = 9.78 + 0.90 + 0.98 + 0.99 = 12.65 + VAT
And the Mild Steel set = 4.51 + 0.78 + 0.86 + 0.91 = 7.06 + VAT
Each set comprising of a plate, 1 disc & 2 rings. At some point I'll try to update the spreadsheet with what folk are likely to pay for their specifics.
On the subject of laser marking\etching - I know for a fact the MS plates will come marked\etched - but I believe the AL won't even tho the above blurb says so. In a conversation earlier the cutters stated that AL is very difficult to etch\mark due to the high reflectivity of its surface. I'll double check this.
The MS plates will have the corner holes centre marked (etched), as well as the 2 guide bush holes and will have 3 lines parallel to the long side so you have something to help when lining a fence up. (Someone suggested this). Sorry that the AL plates won't come etched, turns out the Aluminium just doesn't etch with a laser. With the Alu (or M\S) sets - I'm more than happy to print\email full size copies of the CAD work and post them out\email or whatever. Bit of spray adhesive and drill thru, ruler & Stanley knife and you'd get the fence lines.
Dibs
Ring 1 - 30mm hole
Dibs
