Router bit too large for insert plate
@Sachakins @sometimewoodworker I dont have a table saw unfortunately. I'm a bit limited on space and also very new to this, so trying to be careful with what tools I do buy and get the most of out of them. So I may get one further down the line if I can see myself using it lots (and then working out which one is a whole other quagmire)
Hi stephenharris. I have the same model Katsu router as you. The tool is much more versatile and easier to use when grooving edges and faces when the plunge base is used. Have a look at the Aim Tools web site.
I would suspect it is actually like this..
Can you find one "like this" that is the 50mm diameter that he quotes (and 7/32" wide)? Or is it possible that one of you has mistaken 50mm and 32mm?
