johnnyb
having just installed a rousseau router baseplate and placed a straight edge across the table and insert i see its crowned in a very specific way. the lead in edge in the middle is proud but the corners are flush, the area surrounding the inserts are proud but the inserts themselves are low and the lead out edge is perfectly flush all over. why is this better than a flat table? it is obviously designed this way, my triton certainly doesnt pull it flat. ps i heartily recommend ron foxes method of cutting the rebate(on the wealden site) using the perform 1/2 inch 3/4 deep template cutter is just about perfect with 18mm mdf i also cut the mitre track using this method simple and perfect.
