Woodmonkey
There must be some paint somewhere that needs watching drying
Jacob":3kf9hgct said:I thought I'd join in the waffly burr burbling.bugbear":3kf9hgct said:.....
swarf. But if it isn't removed, merely moved, you get a burr. The burr
(obviously?) extends beyond the original shape of the tool, so metal must have been moved.......
The burr isn't metal which has been moved - it's just been left behind. As the honed edge approaches 5 in BB's drawing, the metal left between 4 and 5 is thin enough to be pushed out of the way rather than honed off. This is really noticeable with some laminated blades where the harder steel of the face can remain as quite a wide but very thin foil, bending upwards as the softer bevel behind it is removed. A bit like grating an apple - the soft insides get grated but bits of peel lift away and remains as a flap still attached (sometimes).
You need to look at things more closely. You can see it clearly, especially with some blades - Stanley 5001 amongst others.bugbear":23kwf33x said:Jacob":23kwf33x said:I thought I'd join in the waffly burr burbling.bugbear":23kwf33x said:.....
Reasonable and temptingly plausible, but I don't think it's true.
If that were the case, the size of the burr would be (pretty much) the distance removed
during sharpening (which is tiny), and it's evident they're bigger than that.
BugBear
I understand all of it. Just as I understood it last time. And the time before. And the time before that. Every sensible or innocent question about sharpening n amount of pages later ends like this.Jacob":2yaphbjk said:Which bit don't you understand?
Jacob":37oqi0qz said:I highly recommend "looking at things" as a way of finding out about them.
Why not go and find a more interesting thread? Currently there's a fascinating one about cleaning old hinges. Might be more to your taste, something you could get to grips with?phil.p":1mz4f3x3 said:I understand all of it. Just as I understood it last time. And the time before. And the time before that. Every sensible or innocent question about sharpening n amount of pages later ends like this.Jacob":1mz4f3x3 said:Which bit don't you understand?
Jacob":1t7ukdzx said:If the burr was formed by metal being "moved" it'd be behind the heel of the bevel, not in front at the edge (assuming you are sharpening in the normal forwards way).
Normal freehand sharpening all the force is in the forwards thrust with the edge only briefly in contact with the stone, as you dip the handle. Followed by a gentle back stroke, if at all. There is no way metal could find its way forwards to hang off the edge.bugbear":29nf5fvq said:Jacob":29nf5fvq said:If the burr was formed by metal being "moved" it'd be behind the heel of the bevel, not in front at the edge (assuming you are sharpening in the normal forwards way).
I think it's usual to sharpen with a back and forth motion - I don't think any body lifts on the back stroke.
BugBear
Jacob":3u5fzqoc said:Normal freehand sharpening all the force is in the forwards thrust with the edge only briefly in contact with the stone, as you dip the handle. Followed by a gentle back stroke, if at all. There is no way metal could find its way forwards to hang off the edge.
Corneel":1y20fa9t said:I just went out to the shop. Indeed, no burrs on the heels of any of my tools, chisels or planes. But the angle is so wide, about 150 degrees usually, that a burr is unlikely to form.
Burrs will form but not from metal moving against the direction of the grinding action. That is impossible and doesn't happen. If you bother to look closely you can actually SEE what happens, but idle theorising is obviously preferred, as ever. :roll:woodbrains":88e87cyy said:....
Burrs will form from moving forwards only on the stone. And it is a movement of metal, this is nothing new, it has been observed as long as people have abraded metal. If the physics as to how things can be moved forwards on this way eludes you, don't argue the point. It demonstrably does happen if you just look.
Mike.
This diagram doesn't seem to have anything to do with sharpening. I think it's just a tease! :lol:Corneel":1dqsmeis said:But what is a burr?
Is it a deformation, like in this picture?
Or is it because of the plowing effect of the grit particles? In other words, is it the material removed?
