David C
In Memorium
Well one never knows.
David
David
Harbo":285jvw74 said:Define modern - 1930, 1960, 1830 ???
MMUK":bokw2f4y said:Harbo":bokw2f4y said:Define modern - 1930, 1960, 1830 ???
1066AD. Jacob remembers it well :lol:
No they were caused by normal use.David C":3cokjzrq said:..
The bellys on old tools are caused by poor technique and hollow stones.
Jacob":1qdcv8yl said::lol: Here phil.p goes again. Why does he bother?
I do think Dave worries unnecessarily about epidemics of bellies on chisel faces. Anyway the new sharpeners call them "backs" so wouldn't "hunch backs" be a better term. :lol:
An epidemic of hunch backed chisels. :shock: :shock: shock horror.
Richard T":23i07rpu said:I'd recommend using a hand cranked grinder Danny, you can take it as slow as you like and control the heat build up. If it is hard work, that's ok as you will feel like stopping regularly to let them cool down. This is a good thing and not a wimp - out![]()
When they are ground back as far as to remove the previous "work" you can use the grinder to put the bevel back. Useful things for emergency situations.
What's ill tempered about it?bugbear":qmjal1zm said:Jacob":qmjal1zm said::lol: Here phil.p goes again. Why does he bother?
Perhaps all this ill tempered sniping could be ended in an amicable spirit by arranging a friendly
get together, where various approaches to sharpening (and the resulting edges) could be compared?
BugBear
If you routinely turn a chisel or plane blade to take off the burr you will slowly remove more material from the sharp end of the face, making it less than flat, unless you flatten the whole face every time.David C":1sgennko said:It is necessary to make the odd comment, to counter Jacob's rather crude misinformation about sharpening.
Use does not create convexity of length on the backs of chisels. This statement is clearly absurd. Convexity is caused by hollow stones and poor sharpening technique, (if it was not there in the beginning from the manufacturer).
David Charlesworth
The main drawback of "New Sharpening" is the time wasted in unnecessary procedures. No-one doubts that it works but it's a time waster and involves a lot of kit.Pete Maddex":fdz4wtgt said:I only turn the chisel or plane blade over on my finest stone, so it would take a couple of life times to have any effect.
Can't you think of a proper drawback to "New Sharpening"?
Pete Maddex":1r61drgp said:Can't you think of a proper drawback to "New Sharpening"?
Jacob":2bk5acxk said:The main drawback of "New Sharpening" is the time wasted in unnecessary procedures. No-one doubts that it works but it's a time waster and involves a lot of kit.Pete Maddex":2bk5acxk said:I only turn the chisel or plane blade over on my finest stone, so it would take a couple of life times to have any effect.
