Taffy Turner
Can anyone help please?
I upgraded my lathe at Christmas to a Record CL4 with variable speed inverter drive. (My old one was a cheapy with belt speed change).
It ran fine for a couple of months, and then started knocking the RCD which protects my workshop out as soon as it was switched on.
I sent it back to Record and they changed the inverter. Everything worked fine for a couple of weeks, and then the problem came back. I returned the lathe to Record again, but this time they said there was no fault.
The lathe still won't run in the workshop, although it runs fine if I plug it into one of the house sockets. The house is protected by an RCD also, but I think it is a higher rated one.
I have received conflicting advice - some people have told me that I must have a faulty RCD, and others have told me that inverter drives are not compatible with RCDs. Record Power are no help whatsoever!
Anyone else had problems with inverter powered lathes?
Any advice gratefully received!
Gary
Gary
