NormanKing
- Joined
- 9 Mar 2004
- Messages
- 45
- Reaction score
- 0
I had this exact problem with an Axminster CT150 planner at my old house. It would more often than not trip the 30mA RCD in the house when it was switched on.
My solution was to take a separate feed independent of the house consumer unit (via an isolation switch) into the workshop and have a separate workshop consumer unit with its own RCD. This totally solved the problem.
BTW, I also have a Record CL4 and have never had this problem, although I do have a dedicated supply run to my new workshop with its own RCD.
NOTE: Both solutions require electrical knowledge and shouldn't be attempted unless you are confident in what you are doing. (I did train as an electrician many years ago before swapping trades to become a computer technician).
PPS, Talking of the CL4, do you know how to access its programming? I know it is capable of having increased speed, reverse and reduced ramp down times.
Despite my badgering Record wouldn't tell me how to do it (who can blame them) so does anyone know how to access this on the Telemechanique?
