I simply have to put up a post on this subject after spending far too much time trying to find an answer to the conundrum that is printing 1:1 in sketchup. The problem has often been mentioned and the answers are at best a bodge job and judging by Sketchup 2013 unless you want to cough up £400 and tie yourself into a £66 a year maintenance contract to get Lay Out then the problem doesn't go away. As 2013 "make" doesn't allow the rather spiffing Boolean plug in I have resorted back to SU8 which for me isn't inferior in anyway to the newer model and has backwards compatibility built into it.
Anyway I digress and please don't think this post a blatant plug for something, which it is, as this is an absolute godsend for woodworkers.
Matthias Wendel has a programme called "Big Print" for sale on his website. I won't put a link it is easy to google if you are interested. This programme takes a design (or photo) correctly calibrates it and then allows you to print out at the correct size. This applies to anything from a few mm across to metres if you desire. It also does proper scaling too. I am absolutely overcome that years of frustration trying to make paper templates from SU has been solved by parting with a few dollars.
Anyway I hope some of you find this as useful as I have. I'm now off to destroy some wood using a finely tuned bandsaw setup by Steve Maskery's excellent DVD classes which is equipped with the most excellent Tuff Saw blades.
