Wow. I’ve not seen that at all. I have a very slow printer so wonder if that is a contributing factor.This is what wet PET-G looks like from my experience.
Fair point. I had similar thoughts about the downside to leaving moisture sensitive filaments on the AMS. It also made me think about dust settling on the reels in an unenclosed environment.Changing filaments on the A1 mini is easy without AMS, couple of minutes at most. I keep my rolls sealed up with desiccant just in case of this moisture absorbing problem so wouldn't want to leave them on an AMS all the time anyway.
In a way it’s good to know that moisture problems present quite obviously rather than finishing a print for it to fall apart to find out! That is shocking how much of an affect it has though.This is what wet PET-G looks like from my experience.
Actually that is a severe case with some crappy Bambu Lab PET-G filament.In a way it’s good to know that moisture problems present quite obviously rather than finishing a print for it to fall apart to find out! That is shocking how much of an affect it has though.
It could be speed like you say and with PET-G extruder temperature plays a large part. The P1 series do print amazingly fast if you let them which is fine for PLA but not so much for PET-G, I've reduced my printing by 50% and increased temps for better adhesion as I found out that if temps are too low it will still print but will also be brittle and break under stress.Wow. I’ve not seen that at all. I have a very slow printer so wonder if that is a contributing factor.
Which brands/types are your favourite/goto filaments? I've only tried Bambi pla basic so far and it seems fine but not sure what to replace it with when I run out. Just with pla there's so many types and brands.Actually that is a severe case with some crappy Bambu Lab PET-G filament.
Normally you won't see any defects until your well into your print because the filament may be dry on the outside but as it's used you're likely to find moisture deeper in the spool. This is of course costly in time and wasted filament, very frustrating which is why I purchased 2 filament dryers and no problems since. The Bambu Lab PET-G filament will never see the light of day again.
You must have been extremely unlucky with your PETG spools. I print almost exclusively with PETG on an A1 Mini, with no enclosure. Have never actively dried my PETG filament before printing either.the chances IMO of getting a successful print with an A1 without an enclosure using PET-G are practically nill.
If there is one thing I would not pay any extra for, it is the screen on Bambu printers. They could remove the screen completely and (at least in my use) that would make zero difference.The X1C has a largish touch screen while the P1S has a LCD screen and buttons.
I simply buy the cheapest from eBay or Amazon, run a temperature tower as my first print, set print temp accordingly and the Bambu A1 mini takes care of the rest.Which brands/types are your favourite/goto filaments? I've only tried Bambi pla basic so far and it seems fine but not sure what to replace it with when I run out. Just with pla there's so many types and brands.
My current go to for PET-G is Copymaster3D which comes from Technology outlet who is just going through a rebranding so they're selling off perfectly good filament at discounted prices, I've saved a fortune and would buy more if I had the dosh. You can't really go wrong with PLA so fill yer boots.Which brands/types are your favourite/goto filaments? I've only tried Bambi pla basic so far and it seems fine but not sure what to replace it with when I run out. Just with pla there's so many types and brands.
I hardly ever use the touch screen instead I access both printers from my laptop with full control over everything.I am seriously considering either the Bambu P1S or the much more expensive X1-carbon. The main difference in my opinion is the operating interface. The X1C has a largish touch screen while the P1S has a LCD screen and buttons. Reviews suggest the P1S interface is somewhat clunky. However I see that there are a couple of add ons I have found: one based around an ESP32 (?) board and a 2.8" touch screen; the other from BIGTREETECH is the Panda touch with, as the name suggests, a touch screen of somewhat more generous proportions 5".
Does anyone have any experience of these, or any other similar, add ons with the P1S?
TIA
Martin
Where are you based, currently where I am it 66%rh and I'm suffering.You must have been extremely unlucky with your PETG spools. I print almost exclusively with PETG on an A1 Mini, with no enclosure. Have never actively dried my PETG filament before printing either.
I've been buying my PETG from various places and brands without any issues, except some stringing in one instance where a Bambu spool I received was way too moist, but after 2 weeks sitting in the open it had dried enough to produce good prints from then onwards.
I have a heavily moded Ender3v2 and only use PETG. Never have I had to dry it or store and like prints no problem.Wow. I’ve not seen that at all. I have a very slow printer so wonder if that is a contributing factor.
@kinverkid please correct me if I'm wrong but you are usingI don't rely on the touch screen for anything as far as the prints are concerned. It's all controlled from one of my computers. It's just handy for certain settings, changing filaments and if you need to re-calibrate now and again. It's not a deal breaker. Think of it as the screen you have on the front of your ink-jet printer.
rather than the P1S. However I expect it is much the same with the Bambu. Hmmm!I now use a Flashforge Adventurer 5PRO after cutting my teeth on an Ancubic Kobra for over a year. It was a toss-up between the Flashforge and the comparable Bambu. The only real advantages I could see between the two is that the Flashforge is slightly faster and the nozzle change is a doddle. You .....
