Nice, Lets hope they stay upright .Didn't have much time left today after going into work to do a few bits so grabbed a piece of Oak that was cut 2 weeks ago and turned a podlet, I had to work pretty quick to stay ahead of the splitting and warping but I managed it and absolutely love the red colouration in the bark.
View attachment 187223View attachment 187224View attachment 187225View attachment 187226View attachment 187227View attachment 187228
To be honest I prefer it when they warp and move, I'm justNice, Lets hope they stay upright .
That a very nice piece with a crazy background.I got a quantity of pitch pine given to me from a mental hospital that was built in 1880. The grain was so close it was almost like hardwood. This is the first thing I have turned. If you look carefully there are areas that are translucent and allow some light through.
The video is before i applied oil finish. The two black marks are the original holes from the iron nails. I just used CA glue and sawdust as I wanted to keep them as a feature.
Thats an intresting lump of a log behind the stool leaning against the wallStarted making a Birch/Ash pot cover for a colleague who has fallen in love with mine and may want more later, the birch top was very unbalanced for most of the turning and despite being dry is very heavy, so much so that my live centre has ground its bearings to dust and started spiralling instead of spinningI'm not too surprised, I've done a lot of very unbalanced stuff recently (haven't posted most of it as it's not finished) I've run out of epoxy so can't glue the 2 pieces together yet.
View attachment 187554View attachment 187555View attachment 187556View attachment 187557View attachment 187558
at this point I decided to start on the game pieces for the balance game I started, a few days ago I soaked 4 pieces of 20x20x150mm very very spalted Ash in a pot of Danish oil over night, they absorbed it all by morning, turning them today was...interesting, on the surface the oil was dry but as I cut through it became sticky then wet in the centre, I'm sure they will dry out now they're parted into 10mm discs, along with these I did some mahogany, cherry and some larger willow, next task is sanding and finishing them all, also want to make some heavier pieces from some waste bits of oak and ebony
View attachment 187549View attachment 187550View attachment 187551View attachment 187552View attachment 187553
That's a piece of willow, it's so punky and dry you could carry the weight on your little finger.Thats an intresting lump of a log behind the stool leaning against the wall
Had time for a turn a few days back and decided to use all my leftover of cuts from a door of meranti. Processing them using my table saw ended up with thisusing the thinner baguettes some were to thin so ended up in stephs garden shed as plant markers. Turned these Two on the bottom left were my only mistakes. Then left them to soak for three days in a linseed bathThis afternoon pulled them out wiped them down and they're now drying out on the tableAs for the last larger pieces I'm going to turn them into salt /flour /sugar scoops when time alows. Sneak preview of three I've done
The recess is called a mortise and the "heel" as you call it is a tenonWow very nice. Pad.
I watched a video of bowl turning. The vid showed that in place of a heel they cut a recess and expanded the Chuck into it.
Thought I would give it a go I scrounged so old floor joists pieces from a neighbour who is extending his house.
Got to cut it down to a size the gives me the biggest bowl and I can still fit the odd shaped wood in the lathe
I cut as close to the marked out circle as poss but the wood looks look like a deformed 50 pence piece
It just clears the lathe bed, the tool rest is extended to the max..... will post results..... or not if an epic fail lol
That's a beautiful result. I bet you are happy with thatThe olive ash pot that went wrong View attachment 187823put on my new cole jaw View attachment 187825discovered that I will need to buy 8 more screws that are slightly shorter so as to make the plates properly sit flush against the chuck face. But still did the job. The only draw back is it limited to 600 rpm so any high speed turning or polishing is out the window. The end result drying with a coat of tung oil.View attachment 187828
