Doug B
Shy Tot
To make life easy I got very good mate to cnc me out an 8x4’ arc on a sheet of 18mm plywood I used this as a template for setting out the postsHi Doug
Nice curve and it must be great to have an opportunity to use the 'boat plane' but how did you make the template?
Simon
He also cut me some narrow arcs of the same radius on scrap 18mm plywood which were screwed to the big piece of plywood
You can probably see the saw kerfs cut in the back of the narrow arc pieces in the photo above. As these were the same radius as the large piece I needed a little waggle room as they were set back 25mm from the front edge so a slightly smaller radius, here’s a close up of a kerf cut
