It's now a jarra arra for a aboriginal blow pipeI thought better of you Derek!
Never disappoints!!Oh .. okay ...
Completed in the past 2 months ...
Bedside tables for my son ...
New bed for my wife and I ..
Curved headboard made with laminations ...
MFT with track hinge and fence ...
Parallel guide for K3 slider ...
Regards from Perth
Derek
A very nice and practical bench. Should do you for your woodworking life and then some. I would rate it 9/10. If you recess that metal plane stop so it sits flush then I could give it a 10. As it is sooner or later it will chip your nice sharp plane blade.My new workbench.
2.6m long, 650mm deep. Huge improvement/upgrade over my previous one.
Full build thread here: English Workbench
Are you going to carve them?Not glamorous, but useful.
Fed up with loads of horses filling up the space, so I made some stackables from the most amazing builders yard spruce and rubbish offcuts.
8 more to do.
Hmm, top looks square, but it has a 10º bevel on it.
Bought a load of spare parts to maintain the Makita 1214 saw too.
No it was placed there for photo shoot and client loaded it up it went into a cellar after this that was the garage when I delivered it he couldn't wait to try it out pic taken before digitalNiceBut I hope that isn't where it lives, wine should be kept in the dark ( certainly away from daylight at that intensity ) and temperature controlled.
Hi DougRecently I’ve been making a pergola which involved some curved rails, I decided the easiest way to make them was to laminate 5 pieces of pine 70x5mm together to give me 25mm thick rails, these are strips ready to be glued
The glue I used was Aerolite up 4145 urea powder adhesive applied to one surface then all 5 pieces clamped into a template
The template was covered in clingfilm to stop the rail sticking to it & after 24 hours in the clamps the rail was removed
The rail was cleaned up & a chamfer planed on the top surface to help shed water then tested for fit
Doesn’t look like I’ll get this finished now until next week with the weather drawing in.
You never have enough clampsDoug B, I think you may not have enough clamps![]()
