DBT85":1wlnb96c said:
(I have a tiny cleat section in W1 and I like it... shhhh)
Don’t expect any more help from mike admitting that, one of his pet hates.
I’m planning on 4-5metres of them a metre high. :roll:
More electrics today, a fishing expedition for the two return wires from the floor sockets, Feed wires were found yesterday, both of the returns were directly behind the 32mm exploratory holes which were made in the centre point of the intended socket location. Bingo, ring circuit now goes under the floor and back twice. In the dirty room, cables were run in the wall to be able to go under the worktop by the sink, where the compressor will live in a sound reducing enclosure. The ring cable was fed in to the first socket of six for the room and out from the last, back in to the workshop. The ones in between will be fitted in between tomorrow.
Lunchtime, and the four extra LED panels arrive, so I abandoned the ring and removed the yellowish batten fitting in the dirty room and replaced it with two panels. 8) 8) 8) 8) now, that’s white. Final two panels were added to the workshop, where the wires were waiting already, it only took 10 minutes each.
Popping the last screw in the light surround and DPD arrive with the curtain heater, so that took precedent over more sockets. The fused outlet was installed ready, sparks wants this on a dedicated radial circuit, so it was a case of fixing heater, plugging it in to test, before cutting the plug off and wiring into the fused outlet. I now have the cooling fan, and oscillating twin heat unit finished.
Architrave and skirting board is now at the timber yard awaiting collection, so will have that to do over the weekend as well as finishing ring circuit, radial for the CNC and network sockets.
