Jacob
What goes around comes around.
Why?ali27":jw3sz505 said:I have the narex chisel set. Bought it a while ago. Haven't
used them yet, but yesterday I flattened the backs of these chisels....
Ali
Ali
bugbear":1zon06q5 said:Gary's notion that the authors slavishly copy each other is not borne out - each and every one of them seems to make up whatever seems convenient! I have seen "back", "face", and "back face" all used for the flat side of the blade.
BugBear
Jacob":279wtamh said:Why?ali27":279wtamh said:I have the narex chisel set. Bought it a while ago. Haven't
Ali
Common delusion more like.ali27":s7bym7xn said:Jacob":s7bym7xn said:Why?ali27":s7bym7xn said:I have the narex chisel set. Bought it a while ago. Haven't
Ali
The back of chisels should be flat. Seems to be common knowledge.
Most knives are sharpened equally both sides. They are symmetrical in section, perp to the edge.James C":1p21xliq said:Jacob it's not about flattening the back but polishing it IMO. When I recieved my Narex chisels this is one of the first things I did before honing a microbevel.
Do you ever sharpen both sides of a carving knife? Isn't it the same, or am I mistaken?
Jacob":zno156db said:In my experience it's only on this forum that people call the face the back. Mind you I've had a quiet life.
I didn't realise it was an americanisation. Or should it be "realize it was an americanization" ?
Benchwayze":3ma2q0ua said:Jacob":3ma2q0ua said:In my experience it's only on this forum that people call the face the back. Mind you I've had a quiet life.
As for polishing the flat side, why bother if there's only a slight difference in performance? Sounds like a lot of time expended for little purpose. I make sure it's flat, and that there is enough reflection to use for estimating angles, such as when chopping inlay. (For which a chisel needs to be 'sharp' of course!)![]()
Benchwayze":bz72rpjv said:As long as you don't say 'incentivise' when you mean encourage! Heard that word quite a lot recently, via the BBC, but even my 'murrican spell check doesn't recognise it either with a z or an s. 8)
Anyway. the Narex bevel edged chisels I bought are okay. The striking surface on the handles could be better, but as I don't clout the life out of a bevel edged chisel, no problem. They aren't the world's best, but for the money, they are good to go.
Noel":2suglmeq said:Benchwayze":2suglmeq said:Jacob":2suglmeq said:In my experience it's only on this forum that people call the face the back. Mind you I've had a quiet life.
Such heresy, you'll get burned at the stake
Flat-ish and sharp, end of story.
It's getting less and less! You don't work through 25 grades of grit finishing off with jewellers rouge and a dash of lipstick? Rules are rules you know.James C":30a0117b said:....
Expended time ends up being a couple of passes so not much time at all.
