Benchwayze
bugbear":55gehsks said:Benchwayze":55gehsks said:You have a point BB. But I would not automatically expect 'use straight out of the box' with any plane, because I always hone a secondary bevel. But from all I'd heard about Cliftons, any other work required is minimal if any, and that wasn't my experience with this one. Maybe my expectations were too high?
Given the other facts gleaned from the thread: I would not regard final setting of the frog position, or removal of "warehouse" preservative, or (as mentioned) final honing of the blade to be unreasonable.
If the retailer does it for you, so that the plane is fully "bench ready" that's great.
The main difficulty here seems to be that no-one knows what level of "final setup" Clifton expect the end user to (have to) do, hence my suggestion of a leaflet.
BugBear
Okay BB.
The claim by Clifton is 'Ready to use straight out of the box'.
That is a bit of hyperbole, because I don't expect a new plane to have an iron in the condition I prefer, with regard to a bevel.
However, I would at least expect the frog to be far enough forward to allow easy mouth adjustment. This wasn't possible because the frog was too far back. No sensible woodworker uses a plane with the frog set back from the rear of the mouth.
Matthew obviously knows the planes can be supplied like this, and makes sure everything is right before it leaves for a purchaser. So Clifton are being a bit optimistic in claiming their planes are ready to use out of the box.
The plane I received was unusable, because the frog was preventing proper adjustment of the blade. Also, there was way too much backlash, which is one point that Clifton are emphatic about. Given Clifton's claims, wouldn't you feel aggrieved?
If not, then you are decidedly easier to please than I am, given the claim that a Clifton is 'Ready to use straight out of the box.'
Apart from honing a secondary bevel, I expected the plane to live up to Clifton's claims. It didn't. I was disappointed. This exaggerated claim is something which Clifton should address.
No More to be said.
Regards
John :x
