Running really short pieces through a table saw is something I have never been comfortable doing even after being around tablesaws most of my life. Better to leave the wood longer for the cut then trim to length after. Other safe way is with the work stuck to a sled.That’s really interesting because that’s how it is. I’ll take a picture tomorrow.
I added the “extension” because I’m using it for profiling the soles of moulding planes. I need to run it absolutely cleanly over the blade, there is literally no margin for error, so it needs to run along the fence perfectly. I was finding, with these 10 inch long pieces of wood, that it was impossible to keep the last couple of inches perfectly straight. It would veer off very slightly to the right - there wasn’t enough support from the fence. And to be honest, it worked.
Many of these cuts are partial and very shallow. Like any plane sole, they have a tolerance of a few thousands of an inch. Basically I need to be able to accurately create two similar plane soles that have 15 thou (1/64”) difference between them. TBH it’s engineering as much as woodworking, Amazingly, I’ve been doing it and succeeding with a plain old rabbet plane. But it’s a slow and error prone process. So I am trying to do some (the deeper rebates) with my table saw.
I think that’s likely in my case.2) Finish. I need a really clean finish on the cuts, but I get some saw marks. I’ve tried a rip blade and a fine toothed blade (also vintage!) but it isn’t good enough. Is there a blade I can get or a technique I can use to get a great finish.
I have an old Startrite. I thought a better blade would help but it turned out my fence wasn't perfectly parallel to the blade.
Put the fence to the left of the blade? You'd have to modify the fixing or make a spare one....
To be honest, there is one feature that I haven’t mentioned that leads me to want to ditch the saw, and that’s the tilting table. When cutting an angle, gravity helps the workpiece fall towards the blade. With the riving knife in, this may be theoretically safe (or not) , but frankly scares the **** out of me. Aside from that I’m sure I can make it a useful and accurate saw.
Ideally for precision the fence needs to be as high as the workpiece.
Also I'd fix a block behind at the far end to keep it square against the table and as location for the G clamp back from the face.
Squiggle of candle-wax on bed and fence also helps.
Do they? Mine tilts to the right just like yours, except your table tilts left instead. I guess Tom's tilts right too, judging by the bulge in the left hand side of the case, to accommodate the whole mechanism swinging over to the left......
I realised that for what I want to do, modern table saws may not work at all. The blade on modern saws tilts in the other direction. The Charnwood one in Tom’s post I don’t think would work.
Worth it to get it sorted!What a load of fuss for a few seemingly simple table saw cuts!
Fair enough, I have never owned one, the video of the Laguna I was watching this morning showed theirs tilting to the right so I assumed they all did!Do they? Mine tilts to the right just like yours, except your table tilts left instead. I guess Tom's tilts right too, judging by the bulge in the left hand side of the case, to accommodate the whole mechanism swinging over to the left.
Table tilting to left (like yours) is same as blade tilting to right (like mine and most of them I think).Fair enough, I have never owned one, the video of the Laguna I was watching this morning showed theirs tilting to the right so I assumed they all did!
You can see from this pic why the left side of the fence doesn’t work. The 2nd and third cuts are inaccessible.
You mean like on this £8k professional panel saw its wrong ?You are probably going to think I’m wrong but here goes. The fence shouldn’t go all the way through like that, it is potentially dangerous and could cause a kickback. (You’re not American are you as they all have saw fences like yours) the fence does nothing in relation to the cutting after the teeth have cut (rather obviously) and the hse rules state that the fence should stop somewhere after the teeth and before the centre of the blade, it’s actually a bit more involved but that’s about it.
Ian
