Doug B
Shy Tot
Having watched Peter Parfitt's video I've been toying with the idea that an MFT table might be a good addition to the van for site work.
As I had a load of shavings, off cuts & pallets to take to an engineering mate I tucked a piece of 12mm MDF in with them & this afternoon headed over to his. After a cup of tea & drawing a grid out on the MDF I coaxed him in to firing up the Bridgeport.
First off a little setting up
Then on to the drilling which was made easy with the X Y axis.
The holes are 30mm to fit my router guide bush,
I'm thinking of turning wooden parf dogs, if they aren't accurate enough I could always get some metal ones turned, but I think they should be fine.
Next up a sheet of 18mm MR MDF (hammer)
