The new M4 Mac mini in base config is excellent value for moneyI had to look up what an AIO was and to my surprise it is a Windoze version of my iMac that I have had since 2009. Poor old girl is getting little long in the tooth. I'll save a little and get a Mac mini. I can use my existing mouse and keyboard (I think) and just have to add a monitor and it will likely see me out.
That is to force people onto windows 11 and that opens a new era in software because W11 must have the TPM module, the trusted platform module which is like a security controller within that can enable programs to run. Long term we will end up renting our software like Adobe and MS currently do with some programs and all will end being managed by te TPM. Basically it can allow different access levels to a program, you pay and the supplier provides the access needed but the program is a single program just your access can be restricted to only allow you to use certain functions unless if you want the next set you pay.A little caution re Windows 10. Recent rumours talk about M$ dropping support for it in 2025.
Might need some help on that, I did a full back up over the weekend, to a separate hard drive.when the new machine turns up, you could clone your existing installation using rescuezilla, super easy to use, download, copy to USB stick, boot from the stick and clone your existing installation to a new drive (SSD preferably)
Then just unplug the data cable from the motherboard, and it will boot from the new drive. You could also take a backup of your existing install, rescuezilla will compress the output to a fraction of the original size, save it to USB, spare drive, wherever. If you find you ever need it, it's a ten minute job to reinstall from the backup, bit of a swiss army knife when it comes to computer related stuff, highly recommended.
