At the risk of adding more fuel to the fire I really cannot see the advantage of using a rod for a simple project such as a table. You only have to mark the length of the components once (ie rail length, leg length etc) and use a tee square to mark that distance on all the remaining similar pieces. So you only measure each piece once and transfer that measurement to the other similar pieces, therefore no room for error.
This is no different from (but quicker than) drawing a rod on which you would have to measure and mark the lengths of the various pieces once but then transfer that measurement to all associated pieces.
Clearly things will be different if you are batch producing something or making a more complicated piece. In these circumstances a rod may well be the way to go.
No one method is right in all circumstances. Just as you chose the most appropriate construction method for a piece you should chose the most appropriate method to layout the piece.
Grahame
Grahame
