Thanks for the comment Frank and for the info on the dreadnought files, I just did a quick search for them and they may well be a good addition to my file set.
Thank you for the follow up to Tony, I will check them out
With the saw backs partially done I moved onto the handles.
Like I said earlier the handles wont follow any traditional form, I had a vision in my mind as to how I wanted them to look and I've tried to stick closely to it.
I chose to use maple and cherry for one handle and ash and wenge for the other, I had these woods available to me at the time but I'm still waiting to get my hands on something really exotic.
I love maple and this piece had a small amount of "pip" which was complemented nicely by the cherry.
The dark and light contrast of ash and wenge goes together nicely too and they have a similar open grain structure.
I used them as I was toying with the idea of using a liming paste to further contrast the open grain but after a quick sample I preferred the natural colour and contrast of the woods.
The woods are simply held together by beech dowels and glue, cramped up and left to cure over night.
After some early shaping and adding a 45 bevel to the handles I made a simple jig for cutting the slot in the upper portion of the handle to accept the brass backs.
Using the over head router, taking shallow passes to reduce chatter I cut the majority of the wood away
And then a lot of trial fitting and refinement with hand chisels. I used blue marker pen on the side of the brass backs when pushing them into position in the handle, this then left a mark of any tight spots in the groove which I could then cut away with the chisel.
This is one of the grooves nearly finished, Rather than coming to abrupt square end I'm attempting to add a detail feature to finish it off
And here is the early stages of transferring that detail over to the brass back. I plan to use a piece of round stock in the hole getting the joint as tight fitting as possible to hopefully leave a near seamless joint.
This will require a lot of careful filing and gouge work.
I also drilled and taped for a bolt in the under side of the brass back. This will be fixed through the bottom of the handle when I come to assemble the saw.
