Nick - apologies for the length of this post
I have met you a couple of times and enjoyed our conversations. I have the utmost respect for your skills and the HUGE efforts in bring around GBW magazine. I should point out that I also admire Richard Kell's work immensely.
However, I have browsed all, but purchased only 3 of the GBW issues. From the outset I was very concerned by the tool reviews that demonstrated a strong bias in my opinion.
How can I say this?
How can I back this up?
Well, the current issue is a prime example. The review of honing guides is an absolute joke and I can only assume it was written as a parody of good, independent journalism!
The basis of any argument is critical thought. Critical thinking leads to writing that produces arguments supported by the preceding 'supporting statements'. This is well known and well documented.
So, let's look at the supporting statements made in the honing jig article (these points are made in the body of the article):
Kell
* British made
* Holds blades square (however, you neglect to say that they are held to one side of the jig and, and with most chisels they will be held near the edge of the stone, this is a VERY bad idea)
* Need to make a set of runners for the wheels to roll on
* The set of runners needs to be 1/2" above the stone, yet still perfectly aligned to the stone - even as the stone wears!!!
* The tool's wheels are not in contact with the stone - i.e. no datum or reference to the stone's surface
* Have to make your own wedge to hold the iron (no doubt, one makes several wedges for chisels, varying blade thicknesses etc. )
* No wobble or movement ensuring perfectly straight cutting edges
* Sold as part of the scary sharp system
Veritas
* flexible and holds most tools without making any additional jigs (like a 'self loading rifle' - yes, we've all used those :roll: )
* The roller is referenced to the actual stone (this increases accuracy unless using scary sharp where it is referenced to the substrate)
* Lots of adjustments including ability to easily set for a back bevel
* Holds the tool square against a reference (like Kell) - however, you do not mention that the Veritas allows the blade to be held square at any point across the jig, so chisels may be central to the stone or anywhere else across it
* Can be used for all manner of edge tools (even mortise chisels in my experience)
* Has a set of stops that make setting angles very easy
* Has 3 settings on the roller to allow small adjustments for the micro bevel without re-setting the blade in the jig.
* One can produce curved blades on the Veritas (not mentioned, but a crutial ability if one follows DC or Scharz's advice on sharpening)
* One does not have to make wedges etc. to use it (not pointed out, but an advantage over the Kell)
There is more, but the supporting statements in the article CLEARLY point out that the Veritas is a superior device on a waterstone-based sharpening system.
The Kell is beautiful and clearly well made, but flawed in many areas - except for scary sharp where the abrasive is thin.
But that's not the point is it? You interview Richard Kell, and his jig is 'British'.
So, you chose the Kell despite the facts :roll:
I think this edition of the magazine was the best by far with some very good articles, but it was spoiled by the appalling bad 'review' (personally, I would find the word review inapropraite for this) of sharpening jigs.
Kill the bias, write independent reviews where the supporting statements DO support the conclusion (or argument) and you will be producing a magazine worth subscribing to, rather than one that is mostly left on the shelf.
My own bias? None really, I own a Veritas and it does all I could want but I use a version of the scary sharp system these days and, for a long time, have been tempted to buy a Kell for straight-sharpened blades (jointer, shooting board, skew, spokeshaves) for use on that. I am off ot look at Richard's web page now :wink: :lol:
