Phil Pascoe
How about this for a revolutionary idea - use the plane that suits you best for the job in hand, ignoring everything anyone else says. It really doesn't matter much.
Nope. I see no point.woodbrains":3eh6zjcd said:....
Custard is fairly homogenous, but I would prefer to push a snooker ball through it than a ping pong ball.
Excuse the perverse metaphor here, but I think it conveys the point.
Yes but to get the momentum you need to exert more force. And how would you submerge the ping-pong balls? :shock:Momentum will overcome friction as wall as cutting resistance.
Jacob":1s7bo51v said:Nope. I see no point.woodbrains":1s7bo51v said:....
Excuse the perverse metaphor here, but I think it conveys the point.Yes but to get the momentum you need to exert more force. And how would you submerge the ping-pong balls? :shock:Momentum will overcome friction as wall as cutting resistance.
Ask yourself - does it work with stewed prunes? They help to get things moving apparently.
So this is where you learned your physics; playing with your pudding? I would never have guessed!
Corneel":x38c8owq said:So, putting sandbags in the boot of the car helps to save on fuel? You have invented the perpetum mobile, congratulations.
Which brings me to the second one. Moving a heavier weight from a to b (and back) takes more energy. I suppose everyone agrees about that.
So, that leaves irregularities in the wood. And yes more weight helps but it comes at a cost: more energy.
There are other ways to deal with irregularities. In the first place a sharp blade. "Sharp cures everything".
You can skew the plane, you can plane across the grain in a heavy cut, you can choose your stock wisely, you can wax the bottom. You can even lean on the plane to alter the weight dynamically when you need it.
It's all a matter of perception too. Someone who paid a lot for an extra heavy plane feels more difference them someone who got it for free. That's human nature, not physics.
Corneel":3dvw8tn9 said:The custard example is fundamentaly flawed, you'd have to acknowledge that.
I think where you are going wrong is comparing planing with a swinging action, like hammering. Planing is a pushing action, where the circumstances are different. When you try to push a nail into the wood it doesn't matter if the hammer is 50 grams or 5 kg.
And don't take it too personally, it's just a discussion on a forum, not a matter of life and death.
Just a trifle.phil.p":muwcpwlo said:Fine, but doesn't the muck off your water stone get the custard dirty?
Jacob":2o689ssw said:Hello....No it isn't.woodbrains":2o689ssw said:Duncumb.fc":2o689ssw said:Please also note that a knot, or any other imperfection that might slow the plane, will impart a given return force. This force will slow a plane with more momentum by a lesser amount than a plane with less momentum, true. However, the force required to accelerate the plane back to full speed will be equal to the force imparted by the imperfection in the first place.
Thus, weight and momentum, while making a plane seem smoother in a push, actually do not save any energy at all.
Fraser
Hello,.... I'm afraid your logic above s wrong....
You need to do a bit of physics revision woodbrains.
There may well be advantages in heavier planes on some occasions but it's certainly not a general rule.
Compare axes and hammers - they work by imposing all the momentum gained in the swing on to a brief contact with the target. You couldn't get the same effect by just pushing at nail or an axe head even with the same amount of energy invested - it's the short sharp blow which does it.
Corneel":2o689ssw said:Dear Mike,
You still don't understand this fundamental physical thing, energy doesn't appear from nowhere. The momentum doesn't push the plane. You are pushing.
When you push something at a constant velocity against a constant resistance, you have to deliver energy constantly. If you stop pushing the plane it will stall to a complete stop. The heavier plane will move a little further then the lighter one because YOU have put more energy into pushing it until that point. The same goes for the ball through the custard. If the momentum would do any pushing you would have created a perpetuum mobile and the plane would take of from itself. That is fundamentally impossible.
Hope you now understand what I am trying to explain. When pushing the plane you store some energy into the momentum, so it will continue a liitle further after you stop pushing. But the momentum itself doesn't create energy to push the plane. The momentum doesn't push.
If you don't understand this I'm afraid i can't explain it more clearly.
Wishing you all the best, corneel.
PS, I don't remember exactly who said what, but the custard example and the hammer example came from you.
Jacob":c6v6hnq3 said:6 What would happen if you dropped each of these into very deep custard?
