Duncumb.fc":mhgdprs1 said:
Please also note that a knot, or any other imperfection that might slow the plane, will impart a given return force. This force will slow a plane with more momentum by a lesser amount than a plane with less momentum, true. However, the force required to accelerate the plane back to full speed will be equal to the force imparted by the imperfection in the first place.
Thus, weight and momentum, while making a plane seem smoother in a push, actually do not save any energy at all.
Fraser
Hello,
Like I said earlier, if your preference is for a wooden plane or a lighter plane then fine, I'm not trying to change people's opinions on that. But the original argument was that a heavy plane has no advantage in the respect to being able to sail through ornery stuff, which is not true Nd the point I was trying to explain. I'm afraid your logic above s wrong. Do not try to justify a preference with poor logic, just state your preference and stand by it. The reason these forums run away is that poor logic is used over and over to try to win a point. It is not necessar I love wooden planes and I know sharp irons are most desirable thing and work wonders. But don't use bad logic to prove a point, it just becomes exasperating trying to explain over and over what is often irrefutable.
For anyone still interested, the above situation is not right because the opposing force exerted by the knot, or whatever, is the same for whichever plane is used and the same amount of restoring force will be required irrespective of the planes mass as the heavier one has more momentum in the first place, which is what momentum is. But the plane will not have stalled so much through the cut ( as is correctly pointed out) . At some point a very light plane will stall completely to a stop whereas th more massive one will continue through
Mike.
