phil.p":1gb46jgx said:I have a perfectly good argument for heavier planes. I like heavier planes.
Especially when planing through knots whatever the physics says. Or on any other occasion when they suit the job, mood or day.
Yebbut you don't get anything for nothing - to gain momentum you have to apply more force, so you can get a "chop" effect when you hit a hard bit but overall you will be doing more work. Most of the time you aren't chopping knots, which makes planing unlike using an axe, where chopping is the only option.Corneel":2b8ok7hq said:Ok, I'm going to make some corrections to my own blasphemous posts from the last few days. Fueled by a bit of booze I probably went a little too far.
In itself there is nothing wrong with the theory, but practice showed that momentum can help you in planing hard wood with high resistance. The keyword here is short planestrokes. It is possible to build up enough momentum to get a quite a bit of distance in the wood before you run out of kinetic energy, further then I thought. So If you start a planing stroke at considerable speed, and the resistance in the wood is higher then you are able to just push through, the momentum helps until you run out of it. In the wallnut board I am working at, I guess I can make strokes about half a meter long using the momentum plus my own pushing. This is very usefull in rough planing when you want to remove a lot of wood.
Sorry for stepping on any toes.
