dvddvd
Which Triton router do you have? Do you need to use a collet extension with it?
Email me if interested for more detail rather than clog the system ?Hi how much did you want for both? Thanks
I have not had any issues with reliability using a TRA001 except the inbuilt lift was not smooth but once you use the knob to get it to rough height and only use the handle above the table to fine tune it works. As for fumbling under the table it is not hard to modify so a remote switch can be used and fitting a muscle chuck solves the bit changing once you remove the built in spindle lock plunger. To solve the height issues you can fit it into a Jessem Prestige lift and then it performs ok, plenty of power and does the job. The best solution will be a lift and AUK motor if starting out with nothing. I would always avoid extensions if a muscle chuck can solve your issue because it replaces the existing chuck and you only need a hex key to change bits otherwise it is an extra component in the existing chuck.Triton routers are the worse router you could even use in a table, the spindle lock means grouping around under the table every time you want to change bits, and mine only lasted a month before the bearings needed re-placing.
