thanks Dave, at least it is consistent with the theory that Bailey/Stanley started off with solid steel cutters, then introduced laminated blades later on having realized/remembered that they are quite a good idea (1900s-1920s? No one seems to know for sure) only to going back to solid steel in the 1950s having concluded laminated irons were 'old-fashioned' (possibly abandoning British made cast steel at the same time?).
Here is an article about a sheffield steel maker (Jessop and son) from 1893 that mentions a US plane maker using the other non-forging approach to welding a laminated plane iron mentioned by Andy (referred to as 'roll welding' in the article).
https://babel.hathitrust.org/cgi/pt?id= ... up;seq=334
I found the article via a wkfinetools post below which also mentioned that the Jesson's brightside works eventually occupied 35 acres! This has further shaken my confidence that Record actually melted their own crucible steel since their factory is piddly in comparison. Perhaps the lab they mention in planecraft etc is just for testing/specifying cast steel made elsewhere?
toodles
http://huk1.wkfinetools.com/05-Steel/Je ... hist-1.asp
toodles
![1858-WilliamJessonAndSons-BrightsideSteelWorks-560.jpg](https://proxy.imagearchive.com/c36/c363558478422a2e755322a25868aa08.jpg)
