Farmer Giles
The biggest tool in the box
I finished the base this morning, or one of them, I have another run and an island unit to do after this.
Rivnuts are very useful, these are aluminium but you can get steel and stainless too.
They work just like a pop rivet, however instead of the disposable steel stalk, the screw thread on the tool is used to pull the back end of the rivnut against the material, here's a view inside the leg.
You have to be careful not to overdo or you end up stripping the thread out, just enough to stop the rivnut spinning. I always go round them with a tap afterwards to make sure there's no tight spots when you put the bolt in that could make the rivnut spin.
Here's the finished base, the rivnuts are quite high on the leg, no only because screw in feet could hit the rivnut, but the intention is to bolt the plinth on quite high up so the bolt is not visible unless you get very low down. The face frame will drop down about 20mm or so past the base of the cabinet which will also help.
Now back on the cabinets, once I have the drawer dividers in to support the face frame I'll finish them on the inside with a couple of coats of Bona Mega
Andy
Andy
