Doesn’t anybody use push sticks in America?
Not really, (Well maybe some do).
These (often just a scrap of plywood) are more common than the long sticks
the very idea of spindle moulders makes me cringe.... This spindle moulder video made me cringe
Hi Jar, well it won’t come as any surprise for you to know what we all think of push blocks on this side of the pond, but you have so many accidents over there, – I found a link to an American site saying 10 amputations per day in the US. Would you perhaps try push sticks? There is a thread on here I started a couple of pages back entitled something like New push sticks I made. Once you get used to them they are very easy to use to control the wood being cut, one pushes it against the fence and the other pushes the wood through, And you don’t need to take your guard off to use them. Cheers IanNot really, (Well maybe some do).
So what type of push stick are you advocating? And I’m afraid I don’t understand the last sentence pushing the end of the cut into the rear of the blade?Can't understand why through this entire thread that no body has mentioned that before anybody considers push sticks the main things to consider in table saw usage are as follows.
Make sure that the fence is parallel to the blade.
Use a short fence or a long fence with a short sub fence fitted to it.
Make sure that the blade is sharp and of a type suitable for the cut to be made.
After the above then comes the push stick or 2 if you like in my opinion the birds mouth type are not as safe as some like to think if you take into account that the danger comes from the rear of the blade lifting the wood of the table and that type of push stick does little to stop it and if nor placed correctly on the end of the wood can push the end of the cut into the rear of the blade causing the very issue that we should be trying to avoid.
I suppose it does make a difference depending on the style you ride or where you ride, but potting along. On the main road its likely crush injuries from a motorist will cause the most damage. Offroad those is a different kettle of fish where offs are common, as are trees and large rocks, and going over the bars due to hills it's your head thats likely to contact the ground. There helmets arent just a requirement but a necessity.However on a bicycle it’s much less dangerous, so making them wear helmets would be unreasonable.
Well I would suggest you go back and read all of this thread and also my thread with regard to push sticks a little bit further down the list, 40 to 90,000 Americans every year have to have surgery on their hands and 10 a day lose a finger or hand to table saws, principally because they have to leave the guard off because they are using one of those push blocks which you are advocating. Your life your hands. I would just say that in 45 years of using a tablesaw – always with two push sticks I have never had an accident and I have never ever had a piece of wood thrown back at me . Ian
Edit. Check post Nr 39 on page 2, if you still want to continue using a push block – well I can’t imagine you will.
Personally and certainly based on some of the responses to this thread I think the problem is ultimately down to attitude and mentality. Simply put, people cannot rationalise away the reality of accidents occurring by deciding they are not the sort of people to have them. There also seems to be some minor misconception that safety guards are more useful or applicable to some people more than others. The guard is there as one more tool to ensure the blade isn't exposed and to potentially increase safety, it's not there just for careless people or idiots. Removing it if you don't have to or not exchanging it for other forms of safety equipment if you do is not conducive to safe working.Isn't the problem is placing your hands so close to the blade? Even with a guard, you should keep your hands well away from the blade by using 2 push sticks.
The main issue really for me is what new table saw users take away from all this.
