The two brown wires are the thermal cutout. The thermal cut out disconnects the power inside the switch and shuts the motor off untill it cools enough and then the thermostat operates again and you can restart.
If the motor was running before the idiots disassembled the switch the thermal cut out is fine. You dont need another motor.
The switch is definitely the problem.
Modifying the wiring for NVR switch is possible, and is actually advisable to meet current safety standards because..... As it is (was) the thermal cutout could kill the motor, and while it was stopped you (or someone else) could start handling the chuck. When the temp cools and the motor restarts all by itself youre in deep deep doo doo. Thats what the NVR switch is for, to stop the whole system untill there is a manual push on the button. but its not simple and not advisable over an internet chat if youre not too sure about it.
Your simplest way out is to find a replacement switch. Somewhere on that switch will be serial numbers cast into the plastic. Do a search for that number alone.
If all else fails, take the switch into an electrical wholesaler and ask them for a replacement. Dont explain everything to them, just hand over the switch and say "got another one? They have all the look up charts and if youre lucky and get a helpful man you should be alright.
