What finish to Lime Carving ?
peterw3035
UKW Supporter
15 Dec 2017
Romsey, Hampshire
I'm just completing a wood carving challenge using lime wood. I've split a single block of lime into 3 parts and they are quite different colours?? Does lime darken with age & exposure to light?
Also any recommendations for a finish, I'm thinking either oil or wax. Maybe using a sanding sealer first?
The carving has a textured/carved pattern on its surface.
Hi Peter
I've done quite a number of carvings, mostly in the round and my go to finish is sanding sealer, rubbed back followed by several coats of wax and a top coat of microcrystalline wax, if heavily textured use a soft brush to polish, works for me. One of my simple carvings was finished with Osmo raw but I was never happy as it looks almost artificial.
And yes lime will darken over time, how much depends if it's exposed to sunlight.
here are a very few.
The old timer is lime and only finished last year, the polar bear is probably 25 years old now.
    59.8 KB
    114.2 KB
    38.4 KB
Yes the wood as you realise is all different. I chose that because it was so light to start with. Come to think of it I seem to remember that I used acrylic sealer so it wouldn't darken. The base is sycamore and I tried bleaching that as I wanted it to look like an ice flow, the bleach didn't work but it looks ok.
The others in that pic are lime except the fungus which is a lump of elm from the firewood pile.
I have a number of others including some in walnut which is a favourite and if you ever get the chance to carve boxwood I'd thoroughly recommend you give it a go.
Here's a foal in walnut I carved for my granddaughter last year.
    1.3 MB
