bugbear":18y0v2ei said:Tool bazaar have a MUCH later iron, judging by the way it's marked (lightly etched, like a modern tap or drill bit)
http://www.toolbazaar.co.uk/shop/mountf ... -iron.html
Good clean 2 1/4" wide, 3/16" thick HIGH SPEED STEEL parallel plane iron by MOUNTFORD, SHEFFIELD. Slight pitting in places but basically good. 1 1/2" left to slot.
BugBear
bugbear":3nwqqrs2 said:Here's the blade from the auction:
Pretty modern looking typeface (relatively speaking)
BugBear
bugbear":2peqsoxa said:Mushet Steel dates to 1868, so it doesn't have to be very new...
bugbear":1u9i0s9d said:The HSS appears "laid on"
BugBear
nabs":2kxt2dn4 said:.. and it seems the Stanley HSS irons were available in Oz and NZ for a long time too, so there must have been a demand for them. I wonder if it is practical to sharpen them with oil stones (and if that is the reason they are relatively uncommon)?
Cheshirechappie":32ok6bkz said:However, a long-established practice among turners and toolmakers was to polish the cutting edges of freshly-ground HSS cutting tools to gain a better finish on the workpiece. I've done that, and it works - it works with ordinary India oilstones. However, That's only to take out the grinder scratches. I wouldn't want to remove any bulk from a HSS tool with an oilstone - you'd be there all day!
D_W":zf7n4e9m said:Crystolon stones, on the other hand, have shown to have frightening working speed on HSS. I could make the SGPS fallkniven knife disappear in about 15 minutes of heavy grinding on a crystolon stone, and then the same knife didn't seem to be abraded much by the washita, but it didn't like the washita, either...or anything. Not even loose diamonds on wood. Took an excellent edge off of a buffer with no sign of strangeness.
D_W":2w4k6lvi said:I don't know what level SiC is a finisher, but I have carborundum barber hones, and they're still coarse. The application of a barber hone doesn't involve going all of the way to the edge, but it's still surprising how fast the fine stones cut (and how they don't leave a good edge).
Let alone the mediums. They don't cut vanadium carbides, but since they cut the entire matrix really fast and aren't doing the finish work, so it doesn't matter whether they cut them or not, as long as the removal is fast.
D_W":8jty89kf said:You can get it a bit smaller than that, but there's no reason to. Even at 3 microns, it has an ability to make a bit of a jagged edge.
