Phil Pascoe
David, I suspect some of the people quick to criticise have never used or sharpened the tool in the first place. It's just "I'm better, cleverer, and more capable than you. So there."
Your too suspicious mate, the last time I did my draw knife was day before yesterday (rugby day yesterday) It camme up razor sharp as always does... (hammer)phil.p":342lqnya said:David, I suspect some of the people quick to criticise have never used or sharpened the tool in the first place. It's just "I'm better, cleverer, and more capable than you. So there."
LOL you mean-we have to accept as gospel anything a proffessional says?? :shock:woodbrains":342lqnya said:Hello,
If professional chair makers say the gadget does things better and quicker than without, all negative comments from those who haven't even tried the thing, are completely redundant anyway. If people are trying to appear stupid, they are succeeding. Getting the shave sharp without even rising from the shave horse, for a professional chair maker? I'm not sure I see the downside. Time is money; the outlay is likely to be recouped in a week.
Mike.
I meant the gadget Dave. I guessed you might have had a go with a draw knife at some point.David C":3srwxgd7 said:Well Jep, wrong again. Please stop inventing these ridiculous lies.
I have used a draw knife to make one of Brian Boggs' chairs.
The facets left on the surface make a pleasing change from the smooth flat surfaces of much cabinetwork.
David Charlesworth
Corneel":lj8px4ms said:http://www.youtube.com/watch?v=7lVMcFjoOL4 You mean this video?
And as a reminder for everyone. Let's try to refrain from personal attacks and degoratory remarks. For example, somebody isn't "stupid" because he questions the usefullness of something without having used it yet.
You would need to consult Mr Boggs to find out. Seeing as the device has straight and cylinderical bars for the sharpening, it seems unlikkely it would be any use to create anything but a microtome-like (scandinavian knife) type bevvel.CStanford":2rfqdp07 said:I assume this new jig must be able to accommodate the slightly rounded bevels (on both sides) that Boggs says he prefers in the video link above.
Anybody know for sure?
TIA
David C":2rfqdp07 said:I am simply astonished that so many people who are not full time users of draw knives, are so dismissive of this nicely made guide.
Cottonwood":3cnpepuu said:LOL you mean-we have to accept as gospel anything a proffessional says?? :shock:
What on earth was or is wrong with B Boggs's original nifty and efficient method (on video, no gadget except brown paper to stop grit dust getting onto shave horse) and how would this new gadget improve things bearing in mind he uses rounded bevvels to the draw knife?
woodbrains":blsvxl2y said:Cottonwood":blsvxl2y said:LOL you mean-we have to accept as gospel anything a proffessional says?? :shock:
Hello,
No one has to believe anything anyone says, professional or not. But since Brian Boggs' work is of the highest order, he makes a living at doing so and has done so successfully for a long time, anything he does say is likely to be worth accepting as a very good endorsement. Alternatively, those opinions that come from largely non chair making, very occasional drawknife using commentators, who have not seen nor tried the device in question, can be held in absolutely no regard, whatsoever. And just to clarify; I have not called anyone stupid, but contending that something is not worthwhile without any experience of the thing in question, in light of some who have experienced it and find it does have worth, can only be described as stupid. I cannot see how it could be anything else.
Mike.
Rounding over is bad (increases the cutting angle) but rounding under is perfectly OK. Hampton wouldn't go in to too much detail as the book is cautiously written for amateurs - "the amateur and the younger professional" I seem to recall. Doesn't do to overload with information!David C":wl7ujz8g said:"C shows an edge that is "rounded" , due to inexperienced whetting, and caused by rocking the iron on the oilstone (see whetting the iron).
David C":1haooyvo said:"C shows an edge that is "rounded" , due to inexperienced whetting, and caused by rocking the iron on the oilstone (see whetting the iron).
Hampton is referring to plane irons. The above quote comes from my 1959 edition, which was first publishecd in 1934.
What a great word whetting is.
David Charlesworth
Exactly what I have been saying for years. The rounded bevel is a sharpening expedient and neither aids nor detracts from the cutting action of any of the tools mentioned, as long as the edge is maintained at 30º ish.woodbrains":2nhc57ca said:..... For planes, rounding the bevel is a sharpening expedient, nothing more. The plane does not require it to function. It may well function all the same, but it is not why it is done......
JacobPPS re [i:3g6be3u7 said:The people writing this stuff were not and are not fools.[/i] true but they were writing for the uninformed (almost by definition) and would be inclined to describe "correct" methods suitable for beginners. Do as a I say not as I do.
