Guttering
Croolis
31 Jul 2024
Midlands
Yes, it's more shed stuff.
I've never installed guttering or had to think about it in my life. I've decided my new shed needs it. I want to be as cheapskate as possible. There's an old people's home behind my shed. The nearest building is 30 feet away across grass.
I have a fence (I didn't build this), there's a funny little no man's land about a foot or so wide, then another fence for the old folks' home. Nothing but weeds etc growing in the space between the fences. I'm thinking I could pipe the water from the shed over my fence (the gap is ~half a metre bewteen shed and my fence) and just let it drain into the no man's land. Not even bother with a downpipe, just let it flow out and fall couple metres to the ground in there.
Is this a shockingly bad and mardy thing to do? Will it hurt anything? I mean, I wouldn't dream of putting it straight into anyone's garden of course, but there really is nothing down there. Would it trash the fence? Typical wooden fence panels with the concrete base thing at the bottom.The shed is 10ft by 8ft with an apex roof, so two pipes going over the fence.
If I'm not putting it over the fence, I've got to downpipe it to the ground by my shed and/or water butt it, which I really don't want to do. Pricing this up, I'd be up to 100 quid plus on bloody plastic pipe grr.
Thoughts?
A pragmatic approach would be to do as you suggest and go outside with an umbrella next time it rains to monitor the situation. That would tell you if anything bad is happening and if adding a downpipe would help.
As you say, water falling two metres is going to make a bit of a splash so the effect of that is what you have to assess. As an outside possibility, could you make a pebbled area in the drop zone (bit of landscape fabric under the pebbles), which would attenuate the deluge and stop any rebound?
I shall do that, thank you. I'm seeing cheap second hand guttering and water butts online so I might be able to just do that for a fraction of the cost. Do water butts in the UK fill up in a single downpour with a 10ft x 8ft roof? Presumably one gets rid of the water by just squirting it around the garden. Seems like a ball ache. Never owned one, never thought about one :unsure: .
There is an average UK rainfall chart here:
https://www.metoffice.gov.uk/weathe...-weather/rain/how-much-does-it-rain-in-the-uk
Daily data (not from your area) here:
http://nw3weather.co.uk/wxdataday.php
10' x 8' is about 3 x 2.4 = 7.2 square metres. On the above, the largest daily rainfall was 31mm, so that would be a volume of about 225 litres. That is a little over a standard 45 gallon (205 litre) oil drum.
I wonder if you drilled a small hole in the water butt whether it could then drain down gradually over a period of time. Then it would act as a buffer, stopping peak flows doing any damage but not requiring any input from you. Possibly a wick in a larger hole would stop a small hole getting blocked by debris.
Edit: old guttering can lose a bit of plasticity due to UV exposure, so go easy when fitting it. Warming with a hair dryer or heat gun can help it slip into the clips.
Do ground conditions allow for the construction of a "soakaway" on your property for dispersal of rainwater?
