Fusion 360 for personal use
MorrisWoodman12
11 May 2017
Deepest Sussex
Hi! I've been using Designspark Mechanical for years to design any 3D printed object I require. Others here have recommended Fusion 360 for various reasons and someone posted a video tutorial for it so I thought I'd try to use it again. The first time I found it appeared far too complex so uninstalled it and erased the install download. So the first thing to do is to install it again. However I couldn't find the free version for personal use, just the 30 day free trial. I don't want to spend the relatively expensive subscription for the small amount I will use it.
Does anyone know if Autodesk have stopped the personal use version and if not then where it can be downloaded?
Martin
Rob beat me to it (y) Autodesk don't make it easy to find as they want you to pay for obvious reasons.
I use the free version for my 3D printer. I find it a bit cumbersome but that's probably because I've forgotten how to use Autocad despite having taught it for a number of years. I'd stick with it and give it a proper go however. There are several other free alternatives around as well that other members are happy with so if you can't get on with it then maybe post a thread and ask the question.
I’ve been using sketckup for years and have wondered about Fusion. How easy do you think it would it be for this old bloke to learn? I’ve used sketchup for 3D printing with Cura. And as a design tool.
It depends on your attitude aand capacity for change as we're all individuals but it isn't that hard just different. It's free and easily removed if you don't get on with it so what do you have to lose except a little time by giving it a go. I'll be 76 next month so if I can do it.................
That is a very subjective question. It is impossible to answer. A lot depends on your skills, thought processes and attitude.
Form the other direction, it is problematic for anyone who does attempt an answer as most of the time answers are given without reflection on the skills, thought processes or attitude of the respondent, which inform the words that same person is about to write.
You might be a Michelin chef; I can burn a pot of water. And neither of us knows the other's talents. So advice regarding cooking based on that level of mutual ignorance (lack of shared knowledge) is worthless.
A practical piece of advice would be to close off that part of your mind which knows Sketchup when approaching Fusion - treat it as completely new, not as a potential rival to that with which you are familiar.
What can travel across is concepts - the many ways to go from a 2D object to a 3D object, the use of symmetry (reflection), arrays (repeating something in a regular pattern). These are 'how' at an abstract level not 'what button to press' in a specific software.
Well, having arrived at 76 a few days ago, I'm up for the challenge so why not give it a go @Cooper . Mind you when I tried before I couldn't get into it but I'll try again using the YouTube videos. Search for 'Day 1 of Learn Fushion 360 in 30 days for Complete Beginners! - 2023 EDITION '
Have fun
Martin
If you can use sketchup and cura then Fusion should be no problem. I moved from sketchup a few years ago.
There are some differences in the way Fusion works compared to Sketchup which are a bit confusing initially as it seems counter intuitive if you are used to the sketchup way. However, once you "get it" I think it is a better solution overall and now sketchup seems counter intuitive to me.
You have to be prepred for a little time to get used to it, there are some excellent youtube videos to get you going.
Thank you all for your encouragement, I’ll have a go and keep you posted!
I should manage as I’m only 74 and 30 years ago used to teach Geometric and Engineering Drawing before it was taken off the National Curriculum!!
I wouldn't take your teaching as a given. I taught Autocad to college students on a part time basis but when I came to use Fusion which is from the same stable I'd forgotten it all. :oops:
You soon pick it up though even from scratch and if you get stuck on anything a quick google brings up the solution and there are usually several ways to achieve the same objective.
Good luck with it, I've been doing some today, the more you do the easier it gets of course.
74! A mere youngster 😂 Go for it @Cooper if it stretches your brain all the better. You'll lose it if you don't use it. Much better IMHO than simple logical puzzles.
Does fusion use the same command set as autocad?
Does Fusion use the same command set as Autocad?
AutoCAD is primarily a 2D drafting program. Fusion is a 3D modelling program.
Where the functionality overlaps (e.g. drawing a 2D circle in Fusion or a 3D cylinder primitive in ACAD), they are likely to be very close if not identical.
However, at some point you reach a fork in the road where 2D concepts no longer apply. Then you meet new ideas like extrude, loft, sweep, revolve which have no 2D analogue.
For some people, having no prior knowledge of 2D CAD before starting 3D modelling can be an advantage.
Saying that in another way, sticking too closely to how you did things in 2D can be a positive disadvantage when going into the 3D world.
For some people, the ability to reconstruct a 3D object in their mind from three 2D orthographic projections can be a great benefit.
Hence, it would be useful to reflect on why you are asking that question and what you intend to do with any answer you receive. Some things you have to approach with an open mind and just try them.
@ChaiLatte - I used Autocad 1, with two 5" floppy disks ;-)
At home I've used qcad for a long while.
Noted the 3D aspects of Fusion are 'outside' acad.
Never worked in 3D, curious about extrusion etc. No more.
I agree with Chailatte though I didn't find any disadvantages having taught Autocad, possibly because I'd fogotten most of it. Autocad was on versions 12 - 14 when I stopped.
Why not download the free home user version and give it a go. Costs nothing, has all the features you need as it's not an evaluation copy and it's easily removed if you don't get on with it so nothing to lose. The main limitation is that saved files are on line and there is a limit to how many you can save but easy to get around as you just export them to your computer and delete which frees up space for more.
If you don't have any prior experience in 3D then perhaps have a look at Onshape instead/as-well. It is another parametric design tool. I'm no expert but my son has recently taught himself to use it quickly for generating metal frames, wooden parts, and 3D printed gears for his DT project. He had prior experience in TinkerCad and had done some work in Fusion360. TinkerCAD was too basic for him after a while, and Fusion360 was a drain on his slow laptop. Onshape processes in the cloud so gets round that issue.. Downside is that your documents are public so anyone could view them - not so good for commercial operations, but fine for hobby users. There's lot's of training on the site, and as usual via YouTube etc. Easy to find the free version as well https://www.onshape.com/en/pricing
I have tried to down load but I've only got a 30 day trial. It seems to be cloud based and not a program on my computer, as the sketch version I use is.
Is there a version that isn't cloud based?
I looked at a few you tube starter videos but they have so much talk about the presenters CV. (If my lessons when I taught had a fraction of the waffle my classes would have slaughtered me!!)
I'm trying to construct some simple shapes eg a pyramid etc but can’t find a way. I’m sure I’m missing something.
How did you get started?
This guy got me started. The truth is he's really quite slow, pedantic even and even a bit boring, but he does explain the essentials pretty well and sets you off in the right direction, which is really good. Build on these basics.
Anyway, a pyramid.
  1. Select Sketch, the third icon from the left at very top of the screen grab image below. 'Sketch' a square having selected the 'Top' plane with the centre point of the square aligned to the 'Origin' using dimensions. Finish sketch.
  2. Sketch 2. Select 'Front' plane and erect a line from the 'Origin' to whatever height you desire. Finish sketch.
  3. Next. Select Loft command, visible at very top left in image below. Select profiles as indicated in the image below. Say Okay.
  4. Pyramid complete. Slainte.
Hi
You should be able to get the completely free "personal use" version from the site I've linked below. If not do some google searches as it is available although clearly they would rather you paid for the full version so don't make it obvious.
The program does install on to your computer but the files you save are cloud based and limited (I think 10 or 12) however as I said previously it's not an issue as you just export those you want and keep deleted any others to make space for new ones. The program has regular updates and is fully supported.
I use it as IMH ( might not be those of others) it's the best free prog available and suits my needs, it may or may not suit you of course. I use it on a laptop powered by Win 10 btw.
The easiest way to learn is just play with it and when you get stuck with something googl it and you'll usually find a video to refer to step by step.
https://www.autodesk.com/products/fusion-360/personal
