My current bandsaw, a sheppach basato 4 which I've tuned up. I agree on chucking the original blades away. Here are a few companies to consider for bandsaw blades. KR saws. they specialise in making blades for resawing as well as the wood and metal trades.a great company and I sing their praises. There's also the company who make the ripper 37 blades for resawing. they are absolutely amazing blades which can produce fast cuts in lumber ready for planking and much more. I've used the ripper 37 for a while for milling hard and soft woods and it gives me an amazing work load. The blade I'm using now. well I say using now. I've installed it new and haven't used it much is a masters blade from KR SAWS. I love it to bits. it produces a fine cut even though it's a resaw blade 32mm wide with a very powerful hook type tooth setup. unlike most blades where the blades create a clearance above the thickness of the band, this blade leaves minimal deflection as the hook design is flat with the grinds produced as set angles.
Anyway the bandsaw is well built for the price range and offers plenty of power even when resawing. a decent cast iron table gives a smooth feed. 2 speed drive which can make resawing work a breeze with supertooth blades, etc. Besides this, it's quite easy to set up and run. I like it a lot.
This machine's for sale.
considering a larger machine for heavy resaw work and joint cutting. so looking at a basato 5-2
lew
