My Record Power BS350S arrived on Monday, opened the box and it was love at first sight
Had never used a bandsaw before but after setting it up, I couldn't leave it a lone. Made the mistake of not ordering the wheel kit, the basic wheels where OK moving the machine before I put the cast iron table on, but after! I ordered the kit on Tuesday and received it first thing Wednesday morning. Will update once fitted.
I cut what would be best described as a mouses door, the type you see in skirting boards in cartoons, then I tried a veneer, both cuts were made in pine. The veneer came out at 0.79mm at one end and 0.84mm at the other, hopefully this is an acceptable tolerance although I will try and adjust the fence when I have a bit more time. All in all, and although I have nothing to compare it to, it's a lovely machine, big cast iron table, cast iron wheels, two speed, lots of levers and knobs, and safety switches fitted to both doors.
