• If you have bought, sold or gained information from our Classifieds, please donate to UK Workshop and give back.
    You can become a Supporting Member or just click here to donate.
For Sale Felder FB 450 Bandsaw 3 Phase - 1Ph conversion available
7 Nov 2022
Northamptonshire
Rare opportunity to Purchase a Felder 450 Bandsaw in excellent condition.
Fully user refurbished Felder 450 bandsaw, fitted with GL 356 industrial bandsaw guides and solid cast iron band wheels which ensures smooth running and good power delivery under load.
Capacity 440mm throat (blade to Post) Deep cutting capacity 225mm 9-inch.
Table size 58cm wide 42cm deep and tilts to the full 45 degrees unlike some models
This is the smallest of the full professional felder bandsaw and is no bigger in its floor space requirements of many smaller bandsaws which have to be mounted on a base or cabinet.
The perfect balance of size versus operating capacity for the home workshop.
Height -180cm Width including table –79cm O/A Depth 65cm
Blade Capacity 6mm up to 30mm
This machine was stored disassembled so had been completely stripped and rebuilt with new bearings to ensure that it is in perfect condition.
The saw has been in use since the rebuild and tracks and cuts perfectly
3 phase currently running off a phase converter can be fully converted to run on single phase by fitting a digital inverter.
Price to Forum Members £1100
Collection only near Towcester Northamptonshire
Custom options available at additional costs.
Manufacture and fitting of table edge mounts compatible with Felder / Aigner or home made extension tables £150
Permanent installation of digital phase inverter £250
    1.5 MB
    1.6 MB
    1.3 MB
    1 MB
    1.3 MB
    1.5 MB
    1.2 MB
    1.5 MB
    3.9 MB
    4 MB
Price now reduced to £800 cash on collection,
I will be putting this into storage at the end of January so there will only be the opportunity to see it running until then.
Hi Never enough space
Did your ever sell your bandsaw?
Just to clarify, it now runs on household supply?
Why are you looking to sell? Sounds like you put an awful lot of time and love into it.
Steve
