fraser
does it matter what hp it is?
Wildman":1myldv19 said:HP has to be sufficient to power your motor, They are usually marked with the rating.
fraser":5ysaomi4 said:No, the planer is only 1.5kw but the converter is available locally and for a good price hense me considering it. Think the max motor on it is 4kw.
I only have a standard 13A breaker, is this going to be a problem? And if so, would using a converter with a max single motor size of 1.5kw be more suitable? Viewing the converter tomorrow morning so any help ASAP would be great!
Ps bob, someone also told me to come to you about the possibility of recommending some digital read
Outs?
merlin":1rdaxphx said:When I fitted mine the installation book stated that it required a 4.0 mm feed cable and a 25A breaker. ( the book is only a sheet )
I ran a new cable from my board in the workshop with its own feed with the bigger breaker.
If I am right the one you are looking at is the biggest in the range (if the kw rating is for a single motor), in that case it would need a 6.0mm cable and a 40A breaker on the mains side and a 20A breaker with 4.0mm cable on the 3 phase side. That said the latter would be if the converter is being used to its full capacity?
Merlin
