nev
Evening all.
I'm part way through stripping an extractor motor for a bearing change but time ran out today so will continue tomorrow. Just to expedite matters and hopefully prevent any breakages does anyone have any experience with similar?
After half a gallon of 3in1 a bit of heat and a lot of patience I managed to remove the ally fan from the steel shaft and got to the front bearing which popped off without much persuasion so now on to the rear. I cannot see how the rear cooling fan is affixed to the commutator (?) shaft but looks like it could just be a push fit but seeing as its made of plastic and I'd rather keep it one piece does anyone have any idea how its assembled as there is no obvious bolt/thread/fixing as far as I can see, and the plastic fan I doubt would survive even a friendly puller.
The 'bolt' in the fan centre has no socket for a hex key or similar just a round dimple.
many thanks in advance
