bugbear
Woodchips2":5af7lj4h said:What's the advantage of having the pin at an angle rather than 90 degrees?
That was one of the main points of "discussion" in the rest of this thread!!
BugBear
There isn't one really. The "improved" version is a bit notional. There are millions of them out there which nobody has felt the need to improve in this way.Woodchips2":1ortzubz said:That looks nice Paul albeit chunky =D>
Regards Keith
No they don't. Many mortice gauges have a button (if it's not been lost which is often the case) but this is to protect the brass slide from the screw end. The screw has two function on a mortice gauge - to hold the body and the second pin in place, so a finer thread giving greater pressure is needed.Pete Maddex":1ortzubz said:....
You don't need a shoe if you plane a big flat on the edge used for clamping, but you will get problems with it moving when tightening, most gauges have a pad to stop this happening.....
The basic marking gauge is a highly developed item - which is why it has barely changed from the Mary Rose example above, to the modern day. Millions of earlier woodworkers weren't all mad you know Dave, waiting for the new woodworkers to put things right! :lol:David C":3pa7dg0p said:....
The basic marking gauge is cheap and crude and nasty, maybe ok for site workers.
David
Expensive. Looks pointless. Looks uncomfortable to use. Would you want to mark up a huge stack of timber with it? I think not. Why bother when there's nothing wrong with the ordinary (cheap) pattern?Ed Bray":1pgq75aa said:Other than the cost £69 what do people think of this gauge from David Barron:
http://www.davidbarronfurniture.co.uk/d ... pg=2&id=18
Jacob":2c4v43t4 said:This thing about "seeing where you are marking" (seems to bother Dave too) is a bit of a non issue as you can usually see where you have been marking, from the position of the mark. If not then something has gone terribly wrong. :roll: Maybe a diagram would help?
No it doesn't. I've got one which has been in regular use for 40 years (it's the one I use most often and I do do a lot of marking up). The screw has left a bit of a furrow down the side of the shaft*, but this has no bearing on the use of the tool, which would be good for another 40 years. A very good £2 worth of tool.David C":21wcwfmk said:T....
The plastic screw does considerable damage to a beech shaft.....
Jacob":38q5tf0c said:No it doesn't. I've got one which has been in regular use for 40 years (it's the one I use most often and I do do a lot of marking up). The screw has left a bit of a furrow down the side of the shaft*, but this has no bearing on the use of the tool, which would be good for another 40 years. A very good £2 worth of tool.David C":38q5tf0c said:T....
* both sides actually as I turned it around some time ago.
Ed Bray":3sohc04h said:Other than the cost £69 what do people think of this gauge from David Barron:
Sorry I lost the will to live after the first half dozen pages :roll: I just liked the look of Paul's creation, it looks a man-tool.bugbear":10lypvsz said:Woodchips2":10lypvsz said:What's the advantage of having the pin at an angle rather than 90 degrees?
BugBear
bugbear":2ueurbvz said:Jacob":2ueurbvz said:No it doesn't. I've got one which has been in regular use for 40 years (it's the one I use most often and I do do a lot of marking up). The screw has left a bit of a furrow down the side of the shaft*, but this has no bearing on the use of the tool, which would be good for another 40 years. A very good £2 worth of tool.David C":2ueurbvz said:T....
If it was so un-damaged, why did you need to turn it around ... ?
Perhaps you could find a woodworker to make you a new one. :lol:
BugBear
David C":2qihz2hc said:The arrogance and lack of ambition are really quite breathtaking.
Sight of the pin is a clear advantage to some workers.
The flatsided pin which is like the knife in a cutting gauge improves accuracy in fine work. A couple of extra gauges are not going to break the bank.
It has already been explained how a squareish shaft can be made to lock perfectly.
Removing a few arrisses is not difficult.
I once talked with Peter Marples and he made it quite clear, that as long as he was selling x thousand a year he had no interest whatsoever in change.
The basic marking gauge is cheap crude and nasty, maybe ok for site workers.
David
Noel":1agkxcv0 said:David C":1agkxcv0 said:The arrogance and lack of ambition are really quite breathtaking.
David
David, speaking as a woodworker but, with respect, you do little to dispel the notion that there is some degree of snobbery or superiority amongst some woodworkers. Sure, you're very welcome to your opinion and that's something that'll never change for members on this forum, but your last sentence shows poor judgement. Are site workers some type of lower caste? I know many that take great care and pride in their work. They are no different from you or perhaps many of your students in how they approach and execute their work. Indeed there is one I know who would put many to shame with his level of craftsmanship.
On a general note I fail to see why some feel using "cheap" tools automatically means less skill and poor workmanship. When I first started this WW lark I was swayed by all the posts and magazine articles about buying the latest this and the newest that. Then I happened to meet a very well regarded bespoke furniture maker. I saw him making a chest of drawers for a client and I was surprised to see he was using a square with a plastic stock. He had plenty of other inexpensive tools too. To cut a long story short he told me- "they work, they do the job I want, to the accuracy I need and the wood doesn't ******** care, so why should I?"
PS- he had a few cheap marking gauges too.....![]()
Actually it's the other way round. If you bother to read the thread you'll find that I am criticising ideas and methods but not being offensive to anybody personally (except answering back - I'm no angel!). But a whole mob including yourself start getting on their high horses and being downright offensive even when, like you, they have got absolutely nothing interesting to say about anything much.iNewbie":34k7rwth said:Its funny how Jacob takes his usual swipes and nothings said - Yet Charlesworth gets the rib-poke with one off-the-cuff comment. Laughable really.
Noel":1jakh78z said:David C":1jakh78z said:The arrogance and lack of ambition are really quite breathtaking.
David
Cheshirechappie":2ulo3cjf said:Noel":2ulo3cjf said:David C":2ulo3cjf said:The arrogance and lack of ambition are really quite breathtaking.
David
Noel - far be it from me to criticise the mods, but in this instance I feel you're being a little unfair to David Charlesworth. He has had to endure a lot of needling from Jacob (constantly being called 'Dave', for example), and not just on this thread. The needling, sneering and veiled insult (phrases like 'crazy sharpeners', 'tool polishers' etc, used in a rather perjorative sense) been fairly constant for as long as I've been a member of this forum, and probably longer.
A couple of posts above these, another member suggested that there was some childish point-scoring going on. I rather feel that the whole thread has had that general tone. It was started (despite the title) purely to sneer at one particular tool - the wheel marking gauge.
I think the ideas that Jacob puts forward have validity, and certainly should not be censored. However, other ideas have equal validity, too. I feel it's unfortunate that Jacob feels he has to make his points by sneering and taking side-swipes at others; his message would carry more weight with me (and , I think, many others) if it were delivered in a rather more neutral manner.
Some time ago, on a similarly rambling thread, I posted something like this:
"Here is my method, it is effective and time-honoured, and I commend it to all." - great; we're all a bit wiser.
"Here is my method, it is effective and time-honoured, and you're crazy to do it any other way." - Hmm. Not so good.
I think Jacob has a lot to contribute, and the forum would be the poorer without his knowledge and experience. However, I'm sure we can all put forward our thoughts without the need to insult and demean others, or their different ideas about working wood. The reader can decide which approach suits their aspirations, needs and inclinations. I also feel that Jacob's needling tends to bring out the worst in some other contributors (though I can understand their irritation).
Noel - perhaps I might ask you to consider both sides of the argument? More generally, could we all try to respect different points of view and different approaches to working wood?
