Coaxial cable connectors for TV
Chris152
26 Apr 2017
Cardiff
I've searched the net and can't find my answer.
These two are the connections on our TV ariel cable, one into the wall socket, one into the back of the hard drive. Am I right thinking they're both female connections? I've searched for a new, longer (5m) cable and it seems female to female doesn't crop up where I'm looking.
Thanks, C
I suspect from the proportions those are actually male connectors looking at them, albeit with a tubular centre pin, but it's difficult to be definitive from a photo. If that centre pin fits inside the centre tube of the mating connector it is male.
They're called Belling-Lee connectors if you want to search for them online.
Belling Lee or 75 ohm coax connectors- those are the males, readily available online as plugs (use 75 ohm coax!!) or premade 5m is also readily available online or at most hardware stores in premade 5m lengths (the premade ones usually have the same connector (male) each end but also usually include a female to female adapter to turn them into an 'extension cord'...
Usually about $8 to $15 Australian
This is the female to female adapter.. (note the difference in the center pin...)
Well, hold on to your seats y'all. Impatient to shift things around, I moved the TV, plugged in the internet bits without the ariel and - this is the good bit - it turns out you don't actually need a cable connecting to an ariel in 2024! I went into Freeview, and can watch live tv (etc) from there!!! I'd no idea.
Thanks both, but on this occasion I won't be needing a new cable, it seems.
[Slightly embarrassed, tbh]
Hi Chris152
I can confirm this is the female and the image you posted are both male connectors, I would also point out that the female connectors also has four splits in the outer body to allow room for the male to slide in.
I have used male connectors that look like your image and the hole in the pin is just a different design compared to the dome top pin type; and the hole is smaller than the female connector.
One thing to watch out for- a TV using the internet is dependent on your connection speed and number of devices connected to the router, and can also in some cases use a staggering amount of data each month if you have a data cap...
(I have a 100gb cap on mine- and the tv alone could use it up in a couple of weeks!!! after that, the speed is capped on my internet connection and that really slugs things down...)
Just something to be aware of...
