David C":1bc7btj3 said:
I knew this was going to get silly........
I defy any one to produce an accurate dado groove or housing across a wide cabinet side with a chisel.
The sawcuts are not likely to define a precise depth either.
I feel that these ridiculous dissagreements about technique are rooted in practical requirements for different trades.
I have no intention of lecturing Jacob in the art of Windowmaking and Joinery at which I am sure he is very good and I am not!
David Charlesworth
You may have read into this thread something which I do not see, DC. I see no ridiculous dissagreements, just an exchange of differing methods. Even if the end results would not [in my case] reach your standards for fine furniture if I created a dado start to finish using a backsaw and a paring chisel, it doesn't make a simple saw and chisel a ridiculous or silly discussion.
I think for myself the issue is the difference between defining a dado and finishing off a dado. I probably didn't make myself clear when I took your previous quote as a take-off for my reply.
While I have made dadoes start to finish in the manner described, saw and paring chisel, I do not do so in general. Most especially for finer furniture. But wasting a dado after defining its shoulders has been done this way for a long time, including finishing them off. It is by no means "the" way or only way, but I have done it. And if one is using woods such as the Bubinga and Jatoba I love to use, well, it would be a difficult task.
btw, the saws I have used to cut dado shoulders have depth stops to them. Pretty difficult to not cut to the depth desired.
If someone wanted to learn to make dadoes by hand, what methods would you teach them and what tools would you suggest them to use?
For stopped dadoes, I would suggest a brace with appropriate bit, a stairsaw or backsaw with depth stops, a chisel to quickly waste material and a router plane. For through dadoes, I would always suggest a dado plane of appropriate width. Should that not be a possibility, I would suggest the same tools as for the stopped dado, sans brace/bit.
If the person wanted to use just a saw and a chisel, that I would teach them as well. I think the person would need to be able to accept its limitations, but they could learn to do so with just those two simple tools.
Take care, Mike
