But don't the US Smurfs eat grits?
They do, but eating grits makes them dull, you know! Imprecise, kind of slow.
Well I'm disappointed now it's not real. But mine is!Similar to womble doodoo I'd have thought.
Yep, tried them when I lived in Houston. Disgusting slop. Slainte.(I'm assuming folks here have eaten grits - at least one or two.
Lots happening on the bench at the mo!Well that's a messy corner.
Bit of context for you Adam, incase your ocd was twitching!Well that's a messy corner.
S
I think that I've still got a long way to go to get any cop at sharpening, but I do feel like your advice has got me to a point that I can actually start improving from. Thanks to all.
Still need to buy a strop.
Well nobody has ever asked a question about sharpening before.Sweet Jesus, what happened to my thread?.......
I'm also a beginner and one invaluable piece of advice I learnt is keeping going till you feel a burr edge to edge. I used to see a shiny secondary bevel and assume that's me done but once I started to feel for the burr. I noticed I didn't need to go to the much higher grits as the edge was shaving sharp. (don't need to but still do so anywaySweet Jesus, what happened to my thread?
I read the first couple of pages and took away the advice there and applied as much as I was able over the weekend.
I chucked out the micro-bevel. I dug out my guide and found that improved things on the >600 grits. I also found that just pulling backwards (not pushing forwards) on the higher grits also improved things. However I found that with my bevel set to 25 degrees, the edge didn't last long (less than one corner's worth of dovetails), with some chipping out.
Figuring that the bevel was too acute, I re-introduced a micro-bevel at 30 degrees with a couple of swipes at higher grits and achieved the best edge yet, that lasted me through the rest of my box making.
Spot on! Burr especially in the middle of a plane blade - you get most wear in the middle and it's possible to leave it slightly less sharp than the rest of the blade.I'm also a beginner and one invaluable piece of advice I learnt is keeping going till you feel a burr edge to edge. I used to see a shiny secondary bevel and assume that's me done but once I started to feel for the burr. I noticed I didn't need to go to the much higher grits as the edge was shaving sharp. (don't need to but still do so anyway).
All the best.
Box looks good.
You've given yourself a tough challenge doing DTs in thickish oak, both the cutting and the sharpening!
The outer tails look a bit on the thin side - they get called "half" DTs but 3/4 DTs is better.
You've done the DT trick of making them slightly longer - to be planed back for a neat finish, except planing end grain oak is not easy - I'd go for power sander.
I tried autosol on my strop last night. It’s a revelation. My chisels have never been so sharp. Great tipWell after getting through a bucket of popcorn reading this thread I saw only one mention of actual steel used. My 10p worth is it is a case of not only what works for you but also what works for the steel your chisel is made from. I have various grades of oilstones and waterstones which I bought when starting out but haven't used much since. I use tend to use oilstones and a basic guide for working through a damaged (chipped) edge and freehand for honing; this works for me on my dewalt and old sandvik chisels for now but I also have a set of better quality kirschens stored away for which I have promised myself to hone with the waterstones once I've setup my new workshop later this year. I use a scrap of upturned leather glued to a piece of mdf plus autosol for final stropping. I know if I've got it right if I can square out a routed mortise with three strokes and not reach for Thor's Hammer. For context I use the dewalts for building work but I've made furniture with the sandviks all with hand made joints.
