Molynoox
That's super useful, thanks for taking the time to explain.This is way over capacity and probably more than you want to spend
very good machine I have used a lot, quite easy to move on a good surface. The cost goes up significantly when you go over about 2.5 meters lift. If using something like this I would make a small docking point on the wall to receive the front wheels that lined up with the hatch and make a box permanently secured to the forks which pushed open a twin leaved hatch strong enough to walk on when closed.
Come down in capacity and lift height and you get
The attached box now needs to provide some extra height, if your original figure of 2.7m is enough that's only 200mm so no stability issues but the capacity is getting lower and you would have to be careful of any additional weight pushing open the hatch, might want to provide another way to open.
I have only made a brief search you will probably be able to find better with a bit more effort.
Top mounting is significantly cheaper but you need to be very sure of the loading capacity of the structure you are fixing to and personally I would do a load test and issue a certificate to show what you have done, very easy to do, never run a test you believe could fail, always test as if it's going to fail ie. the weight will drop about 20mm load to 200 kg certify for 100kg, photo of structure pre-test, under test and post test showing no permanent deformation, all the law requires is that a test be carried out by a competent person, not defined. Record everything (so any user modification will be obvious). When you make a certificate imagine standing in court presenting it to show any accident was not your fault, if it's not good enough for that don't build the machine.
Most common mistake I have seen with top mounting is a good machine bolted to a wall that will not support the turning moment, some very big companies who should know better have made this mistake and done a lot of damage in the process. Top mounting you usually need to open the hatch first with the obvious fall hazard, if you can avoid this by opening with the load (in a box or cage) I would but then you loose the advantage of everything being self storing as you have the box below to deal with unless it can stay in or be the ceiling when not in use, you still need to guide it on the way up, your rail design would do that well and with a top hoist not need to support significant loads. Lots of good hoists available, how you mount them and to what is the most critical consideration. Do the maths and keep a copy.
Hope my ramblings may be of use - good luck.
The one you posted first is ok on budget I would guess.
I basically have to decide between bottom mount 'off the shelf' lift or top mount using off the shelf hoist but with bespoke design for the connections and such like.
