Niall Church
- Joined
- 22 Apr 2023
- Messages
- 208
- Reaction score
- 11
got a used one of these,does anyone know where I could get a plastic insert for the mounting bracket,this is the square hole the workstop goes into!
+1Show us a picture. It sounds like one of us with a 3D printer might help.
How much would a 3d printer be?just looked again at https://www.mtmc.co.uk/and there are in fact a few stands with parts available for instance https://www.mtmc.co.uk/Product.aspx?ProductID=166138&strReferer=search&PPGR=0 pricey though.
do you have access to a 3d printer? if you have another insert you could maybe create one from the measurements, or track one down on thingyverse??
Ok,I've managed to sort out the insert issue,however,a new issue arises!got a used one of these,does anyone know where I could get a plastic insert for the mounting bracket,this is the square hole the workstop goes into!
unless I've missed something you just need some m6 bolts and some penny washers?Ok,I've managed to sort out the insert issue,however,a new issue arises!
The mount tools that attach to the saw,which then attach to the mitre stand,have m6 bolts that are too small for my Ryobi ems 2026 scl,it's an old machine but works very well! The bolt holes on the saw are bigger 8m,but the slots in the mount tools are M6,so my bolts won't fit thru them!! Any suggestions!
The holes in my mitre saw are 10mm the bolts that came with the stand are 6mm, ,I'm not sure the penny washers will suffice on saw table! Now,you could be right,but, the washers idea looks a bit iffy!unless I've missed something you just need some m6 bolts and some penny washers?
