RogerS
Currently mulling over the next ten/fifteen year plan and as the preference is to stay put, I'm looking at energy efficiency.
Carried out an Energy Survey from the EnergySavingTrust website and frankly most of the recommendations are
EITHER:
a no-no since they wil require the removal/destruction of original features (it's an old, old house with original features, oak beams and cornices) and/or major redevelopment such as radiator resiting/replumbing etc
OR
not cost-effective even over a ten year time frame (such as a new boiler). In any event we run the room stat at a low 16 degrees and augment the rooms that the two of us use mainly in the evenings with logfires.
Fitting additional loft-insulation will be a nightmare as the twin gabled roof has zero headroom since the first floor ceilings are at purlin level. Which also implies that there is a slope to the ceiling and getting any insulation down there is nigh on impossible.
Replacing all the windows with wooden double-glazed windows is on the cards ...well, a bit of a no-brainer really for a woodworker......as would be replacing the draughty wooden floorboards in the main reception room with new ones and insulation underneath (other ground floor rooms have solid floors but no insulation there either) but that's about it unless ........
ground source heat pump...but all the literature says that these are only suitable for a well-insulated house...but if I can generate a lot of the electricity and only use the heat pump to augment the existing boiler then maybe that might make sense.....but am I talking tosh? As I type this, the cost-benefit-equation for simply replacing the existing boiler starts to make sense....
and no grants for doing anything renewable as far as I can make out..too busy bailing out banks, I guess.
Comments?
EITHER:
OR
Comments?
