Phil Pascoe
Yes, you should see the hoops my neighbour has had to jump through doing a garage to bedroom conversion for a customer.
They are all still heated with combi boilers with no provision to change to ASHPs even if they wanted to as no tank space.But is this true Spectric? Or are you merely stating a form of prejudice based on out of date experience? if you read current building regulations that came into force from June 22, there have been definite measures to improve U values, insulation, air leakage etc. Lenders have also begun to change policies to favour lending on well insulated homes (according to MSM recently), and consumer behaviour is bound to change (or has already) given recent massive price increases for energy. Everyone I know who has bought property in the past year or two (maybe 8 people) has been very focussed on the efficiency of the property.
Modern building methods are also changing quite rapidly with interlocking thermal blocks, insulated prefabricated wall panels etc. I have watched a number of new builds go up near us in recent years. Whilst there was a bit of a rush to get some done before new regs came into force, the standard of insulation in houses currently being built near us in Kent is far higher than it was a decade ago. The standard of finishing is very variable though.
The social housing estates being built here all have solar panels.The only house with solar panels, on the 350 house new estate next to me, was retrofitted by the owner.
1 litre of oil and 1 cu ft of gas, I’ve used 60% and 90% boiler efficiency
When we first installed our GSHP we were regularly blowing fuses on one of the phases in its 3-phase supply and the wiring feeding power into the fuse board was getting hot because it was overloaded. It turned out that the supply to the house was actually a lesser standard than all the records showed, so at some time in the past someone had pulled a fast one and saved some money on the cable that was installed. We had to have new cabling to the house to fix the problem. It had not occurred to me before now that the blown fuses were caused by a power surge at GSHP start up, but it would certainly fit in with our experience.Heat pumps have a problem which seldom, if ever, gets mentioned.... The start up current is higher than the running current requirement and this surge on the mains infrastructure is very high.
I think you'll find that this is a feature of all electric motors. I was of the impression that a lot of motorised appliances, such as fridges, washing machines etc. were being built with inverter drives these days, one of the reasons that new RCBOs are being introduced, which I would have thought, with my knowledge born of studying "The Boy Electrician" could alleviate the startup surge. Maybe the motors in ASHPs are much beefier than those in white goods, and inverter drives would be costly.When we first installed our GSHP we were regularly blowing fuses on one of the phases in its 3-phase supply and the wiring feeding power into the fuse board was getting hot because it was overloaded. It turned out that the supply to the house was actually a lesser standard than all the records showed, so at some time in the past someone had pulled a fast one and saved some money on the cable that was installed. We had to have new cabling to the house to fix the problem. It had not occurred to me before now that the blown fuses were caused by a power surge at GSHP start up, but it would certainly fit in with our experience.
It seldom gets mention because the starting current of an induction motor is always higher than the running current. It always has been.Heat pumps have a problem which seldom, if ever, gets mentioned.... The start up current is higher than the running current requirement and this surge on the mains infrastructure is very high. This causes voltage drops and pulses which affect the supply stability to surrounding homes during that period. It affects much electronic infrastructure too. This is made worse by inadequate cable capacity in the street and the further distribution network.
Now add to that the extra current needed to charge electric vehicles and you have a recipe for a worsening situation.
We are slowly, but accelerating, disappearing up our own orifices and we can feel the manipulation we are subjected to if we stop for just a moment or two to think about it. Unfortunately we haven't got time because we need to work even faster to just keep up.
Excuse my ignorance, but how does 7kw equate to 5 amps?When talking about ASHP startup current, I don't know where posters get their "facts" from. Regardles of pros or cons. I installed Misubishi Ecodan units 7Kw ten years ago. They were quiet and I never noticed any lights flickering when they cut in. The current Ecodan models quote a start up current of 5 Amps from a normal domestic supply. I am currently building a new house (for daughter) and the insulation requirements are massive. To achieve the energy performance level required an ASHP will be fitted (box ticking). My daughter on serving a customer with a well known companies logo (Heat pumps etc.), quized him. His experience (as the companies field service engineer) is that most of the problems with ashp are their installation, he stated that heat pumps consume huge volumes of air and need to be in the open not shielded away. Advice that is duly noticed and has led to us relocating the pump position when it is installed to the West face rather than the intended East side. East would have been a much less obtrusive site.
Lose it on crypto-currency or other dodgy financial instruments ?, Like Thurrock, perhapd ?AJPTemple, You mention local authority funding. The Civil Infrastructure levy (CIL) is designed for that. All developments have to pay this up front (some v. small developments excused), these sums can be huge. What the local authority does with this money is a mystery. Our area (like most in the UK) has seen massive housing developments but there are no new facilities.
I would imagine that 100% insulated is not just difficult, but impossible. Probably more feasible to get an infinitely large bike pump.When we were kids we used to put our finger over the outlet end of bike pump and it got hot when we operated the pump - that is a air-sourced heat pump. It is a very simple principle. If you force air at the ambient outside temperature through a fine venturi it will get hotter. But how much hotter? If the outside ambient temperature is is not too far removed from what you hope to get out then you will have warm energy but I doubt whether it would be hot enough for a bath say. What if the outside ambient temperature is minus 10? The electric pump would need to work it's socks off 24/7 to get the water something above luke warm. Imagine what is going to happen if every house is trying to warm the house up and charge their EV - keep the candles handy!
I agree that to have any chance your house MUST be 100% insulated which is difficult to do if you in an live in an old house. I have neighbour who gutted his house at great expense and fitted a suitable air-sourced heat pump which is enormous on the outside of his house - big motors etc. I feel if we all had this of heat pump the energy used would be a big challenge to the grid.
If I were to go along this line it would have to be a ground-sourced heat pump and preferably put it down a colliery - they always came the surface sweating!
That’s not how it works - the air is the heat to turn a refrigerant liquid into gas (think a big fridge) and then the reverse is done by a plate heat exchanger with water - essentially the heat / cool cycle is in the ASHP and at which point the warm water ends up in the house system. The issue is you need a lot of air as the specific heat capacity of air is very low (ie amount of heat it stores) so that is why there are very large coils and big fans used.If you force air at the ambient outside temperature through a fine venturi it will get hotter.
Legionnaires may require additional electric heating once a week.
