Skydivermel
What he saidTurn the taps on. If the hot and the cold come out at the same rate, it's probably unvented.
Turn the rising main off - if you've still got hot water it's vented.
I've been in the industry for 27 years. There are many factors to consider prior to making an informed decision. Don't listen to you mate down the pub who has watched a YouTube video on ASHP.
If Govt gave grants for the correct insulation then we could all run ASHP. BUT if insulating to a very high degree then we have the issue of moisture retention which leads to the necessity of the correct ventilation system for the property.
#Phil Pascoe Thanks!Turn the taps on. If the hot and the cold come out at the same rate, it's probably unvented.
With respect the analyser is showing the efficiency of combustion not the efficiency of heat transfer from the boiler to the heating system or from the heating system to the property both of which will be considerably lower.my Testo 327-1 gas analyser tells me I am running at 86% efficiency, think I will keep it.
From the data badge you read the input power and the output power. Those figures will give the efficiency that the manufacturers designed the boiler to work at. You will find that it is nowhere near the combustion efficiency of 86% which, as I have said, is not the same as the output efficiency of the boiler.Perhaps so, but how else do you measure the efficiency of a Cast Iron boiler, I think the efficiency of combustion is close enough, temperature setting on the boiler and water temperature seem to correlate, as do flow and return temperatures that also indicate an efficient system.
Indeed, and there are two aspects in fact - one is training and the other is motivation. I mean personal motivation to understand the task and do it well.developers using cheap barely trained tradesmen for building
Then how do you measure the output efficiency of a modern CH boiler on it's annual service, or is the manufacturers data just quoted as a matter of course?From the data badge you read the input power and the output power. Those figures will give the efficiency that the manufacturers designed the boiler to work at. You will find that it is nowhere near the combustion efficiency of 86% which, as I have said, is not the same as the output efficiency of the boiler.
Sadly most LBC departments are now outsourced to private companies who tend to be subject to "commercial pressures"!that is a failure of Building Control.
Thanks everyone, heat pumps are definitely now on the maybe one day pile.
What I was surprised by, because I hadn’t looked into it before is that oil has a much higher BTU/ litre than LPG, approximately 1.5 times. Price wise oil is usually close to lpg. No brainier which is the more economical to run. I’m on oil in my present house.
Heat pumps have a problem which seldom, if ever, gets mentioned.... The start up current is higher than the running current requirement and this surge on the mains infrastructure is very high. This causes voltage drops and pulses which affect the supply stability to surrounding homes during that period. It affects much electronic infrastructure too. This is made worse by inadequate cable capacity in the street and the further distribution network.I’ve been asked by the head of our household to look into air source heat pumps. We are hopefully moving shortly, and she would like to have an eco friendly heating system in the new residence. I’ve done a little bit of research, and it would appear that financially they don’t financially make any sense even including the £5K government grant available.
My initial work looked at the Kw/H generated from 1 litre of oil and 1 cu ft of gas, I’ve used 60% and 90% boiler efficiency to work out how much it will cost for 10.35Kw of heating energy (equivalent to 1 litre of kerosene which my existing property uses). I’ve looked at heat air source heat pumps and used the optimistic 300% efficiency, however, my reading suggests that this drops down to say 200% (and lower) which I haven’t used) when the air is cool in Winter. The saving with todays high energy costs means that it won’t break even for say 15 years. In fact if the house is highly insulated I will be dead before it breaks even. If I look at energy prices before Ukraine, and oil is going back down in price, the payback is again ridiculous / if ever.
It seems that an efficient air source system needs to run as c40C which is too low for hot water so you need an immersion heater to top up the hot water tanks to stop legionnaires growing (which isn’t I believe included in the 300% efficiency figures quoted). The radiators need to be much larger than for a gas / oil boiler and preferably it should be underfloor if you are to attain the same room temperature. Now my wifey likes it warm (a career running hospitals has made her acclimatised to the heat before anyone suggests running the house at a lower temperature)…..around 22C which isn‘t a big temperature differential for a 40C system, I’m actually wondering in a house that may not be very thermal efficient if it will be possible to attain this room temperature.
Has anyone else looked at how cost effective moving to air source is? Am I missing something?
Whats people experiences, the good the bad and the down right ugly in installing and running such systems?
I think it earns a massive efficiency rating just because it has delivered for thirty years, that makes it resource efficient unlike so many modern combi boilers that can become beyond economical repair after eight years.
The solution to our energy crisis is to build houses with decent insulation and high thermal efficiency, yet we continue to just build these sub standard sheds because the shareholders want good returns. Again our problems come down to greed and not delivering for our future needs.
What an ABSOLUTE load of common sense!Its not even a case of more insulation. If house builders bothered to think beyond the shareholders they could build houses that have huge efficiencies just by there placement. If the majority of new builds faced south they would benefit from passive solar gain. Of course you don't want red hot houses in summer so you put large overhangs so in summer it is shaded and in winter with lower sun you get the gain. You also have green roofs which cool in summer and insulate in winter, and would add to green space in a development reducing the heat island effect of huge amounts of tile and tarmac. solar panels and heat pumps and you'd barely have an energy bills
The above is so so simple but instead we get 1950's style houses built as close as possible to each other with no thought whatsoever. Instead in summer they get red hot and everyone has to run A/C units and in winter have the heating on continually.
There lies the problem, many of these property tycoons are party donors and have a large influence on political decisions, making money is more important than building decent homes for the future so they get away with throwing up sheds. This is more than likely why our building regs have not be modernised to reflect the changes needed and why these developers just cram as many sheds onto a piece of land without thinking at all about location. When you look at these dormatory developments they are packed in so even a south facing shed is in the shadow of others.If house builders bothered to think beyond the shareholders they could build houses that have huge efficiencies just by there placement.
