Lard
Heat pumps as a retrofit to an existing house don't make sense to me, but I do wonder about simple aircon fed from our solar, as a supplement to the gas boiler.
A quality 6kW mitsubishi split with two indoor units cost about £2k plus installation.
These can be run as a cooler or a glorified fan heater with (by the look of things) a 300% COP most of the year in the UK. A lot of asia uses split aircon units for heating through winters colder than ours....
For just a modest outlay I suspect I'd get quite a lot of free heating from one of these and a useful reduction in the gas bill over the year. Once you have solar PV it's all about using up what it generates.
The issue there, is that the sun doesn’t shine in the evening ie when heating is more likely to be required and so you’re then either dependant upon the grid or, if you can afford it (more below) a battery backup system.
We had a 4.2kw solar system fitted about 3yrs ago and it works as well as we expected…..payback between 8-10yrs.…..so much so that a few weeks back I contacted the same fitting company and enquired about adding battery backup. Their own estimator/designer gave me some very basic cost info as well as technical specs and sent me away to do my own simple monetary calculations. A few days later I confirmed (to his agreement) that it was NOT a financially viable project for us…..he then pointed out that he has several enquiries per month where he has to, unfortunately for the company, burst bubbles by illustrating how much the sums simply do not stack up at current costs. He genuinely doesn’t want customers wasting money.
We have a 3 bed bungalow (now with attic conversion) and in the warmer months it only uses ~3-4kw per day (the solar panels obviously helping by doing their thing as they regularly produce 20+ kw/day). However, from roughly mid October to January, when we’d need even more electricity for evening heating, there are numerous days where we don’t even produce 5 kW!
Based on a rough 5kw battery cost of £4k the simple calculations (for us) are as follows:-
If our house needed 5kW in an average evening (highly unlikely but let’s run with it) then, in theory, we would be charging and discharging the 5kw battery once (ie one cycle) per day. At £0.20 per kw, this would mean a saving of £1/day = ~£350\yr……meaning that over ten years we would save ~£3500……given that over this period we may have to change the inverter the overall cost (battery and inverter) would be roughly the same as the savings…..And so, for us anyway, it isn’t worth the financial risk?
I’m also concerned (having read up on the battery’s chemistry etc) that in the winter months, when the battery isn’t being charged fully, would this lead to battery degradation over time resulting in a reduced battery life?
When you sit down and actually think about it (in our case anyway ) we’d only be saving £1 per day which, on first impressions, seems crazily low given current electricity prices but everything adds up when you multiply it by 30 or 365 days.
