Any gas heating engineers on the forum? Advice needed.
Hello.
The engineer fitted the Hive system and it appears to be straight forward and user-friendly so I'd guess it will cater for all of our needs.
I could have had one of the alternatives you've listed but from what I'd gathered Hive seems to be the most popular with installers so I opted for that but he was willing to install one of the alternatives if I chose to do so but generally they all do much the same thing as far as I could see.
So far the Hive kit/app has been very easy to set up and schedule as a user, far easier than messing about with the old wall timer and although the Hive system is digital it does seem pretty simple and bomb-proof though time will tell on that. Obviously if the internet is down so too are wireless connections but it has the emergency manual override so all is good.
The boiler is covered by a 10 year warranty but I suspect the Hive kit will be typically one year.
During colder holiday periods we've always set the original analogue system to 10-12 deg and lower temps depending upon the time of year. Just enough to keep the chill off the home and prevent any risk of freezing during winter. As we have the traditional insulated hot water cylinder/airing cupboard, the boiler was set to come on for one hour mornings and evenings and we've always had plenty of hot water. During periods when we were away, there was no use of hot water so with the cylinder insulation etc, heat loss from the cylinder was minimal so demand on the boiler was minimal to heat the water.
My OH preferred to retain the cylinder/airing cupboard so that's the new boiler was basically a more efficient like for like replacement.
With the Hive system I have full remote control. What will be nice after a day out in winter, is that instead of coming home to a cold house because the timer hadn't switched in, I can now adjust it instantly and remotely from wherever I am so no more coming home to a cold house in winter. That to me is progress. :)
Hive designed by British Gas ( my x employer ) and while not everything they sold was good I still have my hive ( version 2 ) and tbh ive never had any major issues. I gave up on the hive trv,s but the bulbs for example are really good . They seem to last forever unlike regular bulbs . Get on the hive website ( if you haven’t already) set up your account and you will get notifications of sales and special offers . Sounds like you have got everything else under control so have great winter 🤗🤗
A good decision, system boilers tend to be more reliable as they are less complex.
For me keeping things simple is important, no wireless control as everything is hardwired and I use a basic Honeywell controller that allows six different On/Off periods each day with it's own temperature setpoint. I now only use two of these, one for overnight and the other for daytime and it works fine and if you want more heat just notch it up. This has now all changed in that the woodburner provides enough heat during the day and the gas is only used to ensure a minimum overnight temperature is maintained as these so called new woodburners do not do an overnight burn because it was claimed they were to smokey !
My old system had the Honeywell control unit which was reliable enough apart from the buttons sometimes sticking but compared to the new Hive system it was positively archaic....says he until something goes wrong LOL
I'm pretty comfortable with wifi, using apps etc so the Hive system to me is so much easier than before to adjust the settings once you get your head around the concepts.
With the new boiler being more efficient the initial settings I put into the app on day one when I set it up are already needing adjustment which is so simple and with a couple of touches of the phone screen I can alter the on-off times instantly for the whole week.
Hopefully it's a case of set it and forget about it. I'll also compare and monitor my monthly gas bill over the coming months to see if there is any change or savings from having the new system fitted.
